Brembo?
Old Sep 2, 2004 | 04:15 PM
6MT_Coupe's Avatar
Re: Brembo?
Another question is "where can you buy the Brembos for the 6MT coupe?" I have heard that it can cost up to $500 for the dealership to do a brake job with the Brembos, and that is insane. I would much rather do it myself, but finding those exact Brembos hasn't been easy. Please advise.
Mods:
Aluminum racing pedals
JWT Pop Charger / Z-tube Combo
Old Sep 2, 2004 | 09:56 PM
CKwik's Avatar
Re: Brembo?
To upgrade, it requires that you get new rotors, pads, calipers and possibly the brake lines. From what I hear, the parts are not exactly cheap. You might be able to get an even larger brake kit for your G for less by going aftermarket. I'm Sure Brembo makes a Gran Turismo Kit, AP Racing brakes can probably be bought through Stillen and Stoptech should have a nice kit out for the G as well. In fact, I believe stoptech has a kit that uses 4 piston calipers in the front and rear. It's a bit pricey, but I doubt you'll ever have fade with those.
Old Sep 3, 2004 | 01:46 AM
duke300zxtt's Avatar
Re: Brembo?
For me thay just look good.
Old Sep 3, 2004 | 09:27 AM
Q45tech's Avatar
Re: Brembo?
Number of caliper pistons has nothing to do with fade, just how much the rotor weights and the graph [slope of friction vs. temperature, vs. pressure curve of the pad material and its area.
Obviously the air flow over rotor and pad [pretty shrouded] can remove some of the heat build up slowly.
The average warm pad is 22-40 pounds on the pedal which rises to 100+ pounds as fade progresses.
Ever notice how hard or impossible it is to get a graph of friction vs temperature for a manufacturers pad material.
Only oem pads are tested by US government to make sure they comply with minimum safe requirements at 200F and 600F. AFTERMARKET pads under go NO testing to check compliance. Obviously they are tested inhouse but who knows against to what standards.
Just like a seesaw when you increase friction at high temperatures you lose friction at cold low average temperatures!
Sometimes you can over design a brake system and get into trouble on the street with racing pads which really don't start working till 600F.
The oem manufacturers problem [constraint] is the pads have to work well cold in winter on that first panic stop 30 seconds after the car is started. This is a harder to achieve situation than make them stop at 1000F.
The following is an excellant tutorial on brake pad composition and friction vs. termperature effects:
http://www.sae.org/events/bce/tutorial-bahadur.pdf
Generally pad size doesn't affect single stop distances till the pad gets over 600F so up to 120-140 mph it is a wash.
Pad friction graphs study red then click on green stuff
http://www.motorsportworld.co.uk/fra...tuff-pads.htm.
Notice none of them spec what happens below 50C [112F]!
Old Sep 4, 2004 | 03:52 AM
DragonGcoupe's Avatar
Re: Brembo?
People gawk at the brembos.
<hr></blockquote>
I must agree. The nicely finished calipers just scream HOT. People can seriously get off to those things. Other than that, I like the linear feel of the brakes better.
Black / Black 2004 GcoupeMT. Premium. Splash Guardz.
xx7sephiroth7xx
Brakes
May 3, 2023 07:07 PM
nissandrifter32
Dec 22, 2015 04:28 PM
tadmcmichael
Brakes
Oct 18, 2015 01:47 PM
alessandro
Oct 8, 2015 09:29 AM
boostelevator
Brakes
Oct 5, 2015 08:56 AM
