is there directions on how to remove the cabin filter.. mice??
i have a 2005 g35 coupe. is there spomewhere on here that shows you how to remove the filter directly behind the battery? i suck at working on cars and usually need step by step. i have the plastic and screws above the battery removed, and i can see the filter. there was obviously an animal in there at some point. i cant figure out how to remove the filter and clean beyond that point. help??
i'll save you sometime, but your going to get flamed for this one. just type diy then whatever you want to do in this site and in google before posting this
https://g35driver.com/forums/g35-sed...eo-series.html - this link has various DIY's including replacing in cabin air filter. here is the exact link to the video of the DIY air filter: http://www.infinitihelp.com/diy/gsed...dure_video.htm
Thanks. I was in a hurry before it gets dark here. I got it done. I found acorns. Turd droppings, and maybey crushed up bones In the creases of the filter. I was changing the battery and noticed. I took off that curved plastic black vent behind the battery and vaccumed what I could. I saw the white plastic piece opening to were the glove box was. Hopefully there is nothing between there and the glovebox and under the filter. I will go through the glove box and check soon ad I can. There was a blue cheese dead stinch in my car here and there through the summer. I bet there is something dead through the bowing unit also
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
