Can't open my car! HELP
Old Feb 5, 2010 | 07:00 PM
danielj's Avatar
From: Winnipeg, MB (Biggest/Coldest city in the world)
battery....that fast clicking noise is because the batter is low/dead....happened to me just the other day, when i tried starting the car it would make a fast clicking noise, the older cars used to try to turn over but new ones must have some sort of way of knowing it doesn't have enough power to turn over.
Old Feb 5, 2010 | 07:12 PM
ai_marvin's Avatar
the tow truck guy pried opened the window and stuck this long tool to unlock it from the inside. then i was able to pop open the hood. went to go get it checked mechanic said battery is good probably the connection was loose.
Old Feb 5, 2010 | 07:57 PM
danielj's Avatar
sounds like it...all you gotta do is tighten those bolts...pretty easy
Old Feb 5, 2010 | 10:49 PM
GiantsFan280's Avatar
So in all this time you couldn't figure out that your battery was disconnected? Didn't you mention before that you had to reconnect it or something?
How do you own a car?
Old Feb 5, 2010 | 11:28 PM
ai_marvin's Avatar
actually everything turned on except for the car dont know the reason for it. And yeah I was at work the first time it would not start. didn't have any tools plus a broken arm. still have a broken arm so haven't been able to work on it. hopefully thats the problem, I've had loose battery issue before. Maybe its my driving or I just have bad luck. But thanks to all that helped
newg37
Jul 26, 2015 09:32 AM
simperformance
Jul 24, 2015 11:17 AM
ClwMike
Jul 23, 2015 12:55 PM
apintojr
Jul 23, 2015 10:52 AM
whattf
Drivetrain
Jul 20, 2015 11:19 AM
