Help Clutch sounds like a Dry Clutch Problem
Old Feb 6, 2010 | 03:24 AM
tightvpkid's Avatar
I've been noticing that sometimes when at idle my car makes a funny sounds. Its sounds like a dacuti with a dried clutch like a tick tick noise. Its pretty loud you can hear it from outside the car. But then when i drive it around the noise goes away but sometimes comes back randomly. It sounds exactly like a dry clutch from a ducati. It has to do something with the clutch because if i hear the noise and i press the clutch the sound goes away. Anyone have this problem. Its very hard for me to duplicate because it comes and goes. Do i need a new clutch or something i barely have 30k on the oem clutch.
Old Feb 6, 2010 | 11:42 AM
parhamm1's Avatar
Search it up.... This is the most common complaint of all G35 6MT drivers. It happens in all 6MTs pretty much and there's basically nothing you can do about it except push the clutch in while you're not moving if it bothers you. If you get an aftermarket clutch and flywheel then the sound will just get louder.
Old Feb 7, 2010 | 02:42 PM
tightvpkid's Avatar
its not the transmissions?
Old Feb 7, 2010 | 05:06 PM
scottfedm's Avatar
I have an exedy stg 1 and I dont hear a thing.
Old Feb 10, 2010 | 02:00 AM
NihkG35's Avatar
Had the same issue. Ended up being my throwout bearing sticking.
chinee
Jun 10, 2024 07:48 PM
Daniel k.
Nov 3, 2015 09:52 AM
chinee
Aug 8, 2015 10:11 AM
andrewvk
Interior
Aug 6, 2015 05:51 PM
atk08
Jul 30, 2015 03:12 PM
