Thump noise in my trunk?! WTF?
Feb 21, 2010 | 04:15 PM
hey guys, for a while now ive been getting this thumping noise from the rear of my car, when i go over a bump, speedbump... etc.. i ussualy hear it while im driving slowly (like a parking lot). Its sounds like the noise is in my trunk. But i cant tell. Does anyone else have this problem?
I searched like a **** but nothing seems to be the same thing im talking about.
BTW. Recently i lowered the car.(But this noise has been going on before this was done)
Also I had my rear driver side axel changed. Not sure if theres a wrong way to install a rear axel lol ?
Reply 0
Feb 21, 2010 | 04:19 PM
is your spare tire bolted down?
Reply 0
Feb 21, 2010 | 04:56 PM
Quote: is your spare tire bolted down?
Im pretty sure it is.. But its worth a shot to go check it.. that could be a possibility
Reply 0
Feb 21, 2010 | 04:59 PM
its your rear shocks...internals...trust me...and thank me later.
Reply 0
Feb 21, 2010 | 07:56 PM
yeah, the shocks i would bet on. my left front started clunking as soon as i put my df210s on and they only had like 44k on them. i would also check the surface between the strut mount and the body itself....we've had issues with them having a noise due to some welding slag left on the surface which doesnt give the mount a completely flat surface. we grind the 2 surfaces down smooth and spray paint them over and reinstall everything. but def sounds like a strut or struts.
Reply 0
Feb 21, 2010 | 09:18 PM
ok thanks.. this is all i needed to know. Any suggestions on better shocks to get?
Reply 0
Feb 21, 2010 | 10:00 PM
umm i'm running factory shocks and they are around $200 each unless you can find some good cheap used ones.....but i think you can get a set of tokico shocks for a good price on ebay.....tear it apart to see if it could be the strut mounting surfaces first......
Reply 0
Feb 21, 2010 | 10:30 PM
noise
ive been hearing the same damn noise for weeks,on my passenger rear.
Reply 0
