Will a stock G35 coupe clear Bltiz Rhino ramps?
It'll fit. I use those same type ramps on my car for every oil change.
Just jam them right into the front wheels and inch up them slowly... If your car is a manual, make sure you don't give it too much gas or dump the clutch to fast or you might drive off the other side of the ramps.
If you ever decide to lower your car, you can use the board method. Or you can use the board method now if youre a handy man.
Well, it looks like I couldn't clear it. I have a front lip which is in the way.
I drove the car on some wood planks and then on the ramps, but the ramps kept sliding away...
Anyway, I bought 2 jack stands at Harbor Freight for $13.
I had the ramps on my driveway
They actually aren't Rhino ramps, but similar.
It's all plastic, I'm assuming rubber or some anti-slip material underneath would have helped.
TWASkyliner
Feb 8, 2020 08:00 PM
b2autodesigns
Accessories-Vendor
70
Feb 25, 2017 01:12 PM
