Charging Battery - 2007 Coupe with Smartkey
Old Mar 10, 2010 | 09:06 AM
wncoupe's Avatar
The original battery on my 2007 coupe is dead since the car has not been driven for about six weeks. The car is parked where jump starting is impossible.
I do have a battery charger. I ma concerned about charging the battery since the car has a smartkey. If I disconnect the battery for charging will the smartkey be affected? Can I charge the battery with the battery connections in place?
What are your recommendations?
Thanks.
Old Mar 10, 2010 | 10:16 AM
mapleleaf13's Avatar
mine went dead while sitting in the garage over the winter. I hooked a trickle charger to the batttery without disconnecting the terminal cables and my battery was fully charged the next day .
broke_as_ajoke's Avatar
Not sure if this is any help, but when i took my car to the dealership last week they charged my battery up.. they didn't disconnect anything.. they just charged it while on the car. I don't know if that is the right way to do it.
Old Mar 10, 2010 | 10:30 AM
gary c's Avatar
There's no reason to disconnect the battery, if you're going to drive it get a jump if not just use your charger. Make sure you know which of the terminals is + or - mixing them up would be a major problem.
Gary
chinee
Jun 10, 2024 07:48 PM
andyg35c1
Aug 29, 2015 03:37 PM
SIKKI
Jul 21, 2015 01:55 PM
