Need help, just mounted my rims and looking for some advice.
Old Mar 16, 2010 | 01:40 AM
imdexterrrrr's Avatar
So after a long wait (roughly 5 months) my Work GNosis GS2s came in. =)
Needless to say, I am very happy with the fitment and the look. My problem is rims have thrown either my TPMS or VDC out of whack when driving. Before, I had a set of Volk SF-Challenges and my VDC would trip out at about 60-70 mph - the "slip" light would come on and my car felt like it was taking over when i accelerated. I would have to let up on the gas pedal a little and step on the brake to get it to stop. After putting the OEMs back on I didnt experience this problem but now that I have the Works on, its been occuring again. Only this time, the "slip" light kicks in at about 30-40 mph.
Bottom line is that I'm looking for a solution to make this stop. Anyone ever experienced this problem when running aftermarket wheels? any info will help. i figured there are plenty of wheel gurus out there who might have the answer to this question.
more pics:
dent-age (no bueno) =(:
lippage:
me chillin with an alligator:
MORE INFO on my setup just in case that factors into my problem:
Tein S-Techz
350z struts
20x9.5 +10 front, 20x10.5 +12 rear - no spacers.
245/35/20, 255/35/20.
I don't really notice any other indicators. just the "slip" light. I'm thinking that the wheels are causing the TPMS some problems which, in turn, is causing the VDC to act up? I may be wrong but I've researched the slip light on the forums and have tried every other option that could be the solution (new rotors, brake fluid, etc) and nothing seems to work.
Old Mar 16, 2010 | 07:07 AM
Brettson's Avatar
Wish I could help but those wheels look great! Well worth the wait IMO
Old Mar 16, 2010 | 08:55 AM
danielv12's Avatar
I think maybe your front tires are too big. What sizes are your tires. There has been threads about this. I believe the front tires have to be a bit smaller than the rear, whatever the OEM ratio is. Hope this helps. . .
Old Mar 16, 2010 | 10:18 AM
herrschaft's Avatar
^Try switching to a 30 size tire. The link below should help
http://www.miata.net/garage/tirecalc.html
Old Mar 16, 2010 | 10:28 AM
gary c's Avatar
Great looking rims, nice coupe. (less the dent) I don't believe the difference between a 35" & 30" width would make you slip light come on. I don't know for sure what the answer is, try asking www.infinitihelp.com maybe they know the cause....G/L
Gary
Old Mar 16, 2010 | 01:21 PM
apro06g35's Avatar
your most likely having a problem because your outside diameter of your wheels are very different than the stock OD. I would look into running different tire sizes. possibly a 30 series.
the wheels are sick though!
Old Mar 16, 2010 | 03:27 PM
eurodre's Avatar
the problem is that ur car is telling u why did u get wheels before a drop
Old Mar 16, 2010 | 06:02 PM
DHCrocks's Avatar
you got the wrong tire sizes so it's throwing the lights. the correct sizes are 255/30/20 front and 285/30/20 rear. This is the closest match to stock diamater.
Old Mar 17, 2010 | 01:19 AM
first off, thanks for all the input guys.
I am dropped... in these pics, my car wasnt quite settled yet. I debated on whether or not to go lower but i have skirts and a front bumper that I havent installed yet so i had to factor that in because the roads around here are terrible.
but arent there plenty people out there running stretched tires? i tried to model my setup based on another member's varianza T1S setup... I think his s/n was "jlin015" or something like that. i believe his offsets were +15 all around and his tire sizes were the same as mine? i could be wrong though...
thanks for the compliment. ill look into different tires once all other options fail me. lol
Gary
i think the dent came from some little kids playing baseball in the streets with an actual hardball. clearly, its too big to be a doorcheck and theres no paint chipping so its not another car hitting me in the parking lot or anything. i wanted to dropkick one of them but I didnt see exactly which kid caused it, otherwise I would've asked their parents to pay for the dent removal.
Old Mar 17, 2010 | 01:50 AM
O HELLA OEM.'s Avatar
Looks Good!
Old Mar 17, 2010 | 01:52 AM
Sharkroy's Avatar
Not related to your problem, but it looks like your tires on the rear (at least in one picture, #5) are on backwards (the rotation direction looks wrong).
Also, your problem may be too tall a tire size, if you were after the "stretched" look, the fronts would probably be 225/30
Old Mar 17, 2010 | 02:33 AM
herrschaft's Avatar
Most people that run 20"s use a tire thats 30mm tall because the circumference of the tire is closer to stock specs, which won't mess with the computer.
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
suby01
Not G35 Related
May 25, 2016 03:07 PM
dcsbh1
Oct 1, 2015 03:15 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
Claudiu
Sep 26, 2015 01:04 PM
