Need air sensors replaced... $950???
Old Mar 18, 2010 | 03:52 PM
GiantsFan280's Avatar
I have my car at a dealer after going through a pretty big puddle and experiencing some laggy shifting, delayed throttle response after shifts, and occasional hiccups. Otherwise, the car drives COMPLETELY FINE. I was told the diagnostic said i need 2 air fuel sensors replaced that are located on the exhaust, and the cost of replacement would be $956.
With some googling, I found air fuel sensors which appear to be the ones they are talking about, and the price is only $150. Does anyone have any input here? I really don't want to get ripped off and don't feel like spending a thousand dollars on two sensors.
Old Mar 18, 2010 | 03:59 PM
lilindienplaya's Avatar
the reason why they are called stealerships. If it is the o2 sensors they have to replace them under extended warranty as its an emisions thing
Old Mar 18, 2010 | 04:01 PM
My car is a 2004 and not under warranty anymore. I have a coupe and was told that the sensors on both sides of the car needed to be replaced. They said they are air fuel sensors mounted on the exhaust, and from what I can tell, this $120 dollar part I found online is what they are talking about.
Old Mar 18, 2010 | 04:11 PM
i think for emissions related parts the warranty different and is longer and more miles. heres a link to what i think they are talking about and dont forget you need two left and right https://www.partshighway.com/product...tnum=BOS-15667
Old Mar 18, 2010 | 04:16 PM
I'm figuring these were damaged when I drove through the puddle which makes sense, but the $950 repair does NOT make any sense.
Would these sensors being bad cause the car to run sluggish during shifts??
I'm not throwing any check engine light or any other lights.
Old Mar 18, 2010 | 04:26 PM
mugen_rsx09's Avatar
Why dont you just replace them yourselve and save yourself alot of $$
Old Mar 18, 2010 | 04:28 PM
I don't see how water would mess with them because the actual sensor is go inside the cat And isn't exposed but then again it could be anything Just do a visual inspection under there and see if any connectors came loose or something
Old Mar 18, 2010 | 05:25 PM
340tog35's Avatar
I have a set im not using. PM me if interested
Old Mar 18, 2010 | 05:29 PM
G2FLIP4's Avatar
everything
Its mostly labor costs, do it yourself. Ive changed many O2 sensors on vehicles, not that hard at all. All you need is a floor jack and basic hand tools.
Old Mar 18, 2010 | 06:28 PM
I just picked the car up from the dealer. There's no way I'm having them do ANYTHING to my car after the run around they gave me.
The only issue seems to be the hesitation between 3400-3600rpm in any gear. It accelerates fine through the whole rpm range, but hesitates for a second near 3500. The slow/ delayed shifting is very occasional now. Is this something that could be caused by bad air fuel sensors?
The dealer said the diagnostic threw codes P1271 and P1281, which is a/fuel sensors bank 1 and 2.
MY MAIN CONCERN HERE is just to make sure I'm fixing the right thing and getting rid of my problem. I don't want to be further damaging my car by driving it, and am just trying to be cautious. It seems there are no honest mechanic shops around anymore, I can't get a straight answer from anyone.
Old Mar 18, 2010 | 08:20 PM
Iamnotkento's Avatar
dude replace them your self.....
Jack your car up. Put it on stands.
Find the 02 sensor, unplug the harness, and use a wrench to take it off. Might need wd40.
Old Mar 18, 2010 | 08:46 PM
I would do that but the issue here is not that the sensors ARE faulty, its that the dealer told me they are. And on the diagnostic they sent me, that is under "Past codes stored" which I'm guessing means they were working fine at the time. The dealership was very reluctant to go into detail about the car, mainly because they were trying to ***** me into paying $956 for a part that costs $156.
I'm resetting the ECU by keeping the battery unplugged overnight. If that does not fix my problems, I am going to take it to a reputable shop that I found nearby and see what they have to say.
The only problem seems to be around 3400-3600rpm. There is a hesitation there in any gear, and I get laggy shifts and delayed throttle response when shifting around 3500, especially 1st to 2nd. By the way, my car is 5AT. Does ANYBODY have ANY suggestions as to what could be causing this? As of now I still have NO IDEA what is wrong with my car and I've had it at a shop and an Infiniti stealership.
Old Mar 18, 2010 | 09:32 PM
Footballmania32's Avatar
Take it to Autozone.. Have them pull your codes. If its the O2 sensors.. buy a set, buy a O2 socket.. jack up the car and do the obvious. Everything is pretty straight forward once you take a look under the car. Just make sure you soak them in WD-40. I do most of my maintenance myself and have saved a lot of money. Don't rely on the stealership unless you're still in warranty
Old Mar 18, 2010 | 09:42 PM
Like I said the diagnostic the dealership gave me says it was a past stored code, which I'm guessing happened when I was in the water itself. I'm hoping a simple ecu reset will clear up any issues that could be causing the 3500rpm hiccup and the occasional shift lag. If not, I'll have it in a legitimate shop tomorrow morning.
Old Mar 18, 2010 | 09:47 PM
340tog35's Avatar
Its so easy you can do it in your sleep guy
