is this even possible? (tail lights)
Old Mar 22, 2010 | 10:10 PM
imGdup's Avatar
Question is this even possible? (tail lights)
I want to make my tail lights so that outer ring constantly stays on rather than the outer ring just on as a signal. But when i turn my signal on i want it to still blink. Is this possible and if so how??
Old Mar 22, 2010 | 10:16 PM
Beebo's Avatar
it is possible there is a thread somewhere. ill look for it
Old Mar 22, 2010 | 10:29 PM
Beebo's Avatar
i cant find the thread sorry
Old Mar 22, 2010 | 10:47 PM
FlSHRFun's Avatar
It's a lot of work. The "outer ring" doesn't even have a ring of LEDs that illuminate. Just the signal bulb underneath.
Therefore, you have to take LEDs from another taillight. E_K used some from a 2005-2006 G35 sedan and later a 2007+ G35 sedan.
https://g35driver.com/forums/media-s...aillights.html
https://g35driver.com/forums/media-s...-tails-ii.html
https://g35driver.com/forums/lightin...light-mod.html
Old Mar 23, 2010 | 12:47 PM
imGdup's Avatar
i dont want to put leds i just want the signal bulb constantly illuminated, but still function as a signal, and then do away with the trapezoid (which i know is possible)
Old Mar 23, 2010 | 01:58 PM
bjquinnIUmed's Avatar
I think you're confusing people. Do you want the turn signal illuminated (I'm assuming not) or just want the LED ring (= brake light) constantly illuminated without having the other trapezoid LEDs on?
Old Mar 23, 2010 | 02:03 PM
davidxu's Avatar
i think he wants all of the lights on at night. outer turn signal, middle led ring, and inner trapezoid leds on. but when you turn, the outer turn signal alternates between on and off. when you turn off the turn signal, the turn signal will remain on, rather than off.
Old Mar 23, 2010 | 02:06 PM
imGdup's Avatar
exactly what davidxu said, except for the inner trapezoids being on, i want to permanantly disconnect them
Old Mar 23, 2010 | 02:08 PM
davidxu's Avatar
oh, so you just want to make it look like a skyline tail lights?
i have a sedan, so i'm just guessing here.
for the inner trapezoid, you can just pull the plugs out for it, then it should be off?
for the turn signal, There is a turn signal mod on this forum that does what you want to the side markers, instead of in your case, the rear turn signals. i'm sure you can just splice a wire from a constant power wire and connect to the rear turn signals, while retaining another wire for the turn signal blink? i'm not sure, just guessing
Old Mar 23, 2010 | 02:18 PM
imGdup's Avatar
ok and to do this i dont have to dremel open the lights right?
Old Mar 23, 2010 | 02:19 PM
davidxu's Avatar
you shouldnt have to.
def pm E_K though, hes a master with the taillights.
Old Mar 23, 2010 | 02:34 PM
imGdup's Avatar
ok thx
Old Mar 23, 2010 | 03:08 PM
TofuProductions's Avatar
Ugh.
Here.
This is my car, I have them
Outer ring, ..the inner bulb (where stock turn signal is) still functions as a turn signal.
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
cmesidewayz
Sep 29, 2015 09:28 PM
Jnm07
Sep 5, 2015 01:16 AM
roboeclipse
Lights
Aug 13, 2015 10:45 PM
myaso
Lighting
Jul 22, 2015 10:34 PM
