Swapping the Long block after Timing Chain broke
Nah, it has some good ware left and when I do change it I will change the tranny as well cause it makes noises. Just figured I would do it all at once. It will also give me some time to get together the money for it.
Nah, it took 2 days to pull it and put the new one back in.... Not bad at all. I thought it would take a lot longer but it was pretty easy
Good job on the swap...but you already know that. The oil buildup in the plenum can be stopped by installing an oil catch can on the passenger side, do a search and you'll find all the info you need.
Imo you missed a great chance to polish the entire plenum and cam cover, I would have also polished the inside and honed the cylinder intakes.
I can always take it back apart to do anything new to it.
