a simple offset question
Old Mar 27, 2010 | 11:00 AM
scottfedm's Avatar
Alright guys. I'm wearing my flame suit on this one. Quick question. Which rim would sit more flush to the wheel well? 25mm offset or 35mm offset?
Old Mar 27, 2010 | 11:02 AM
JBF's Avatar
JBF
the lower the number, the more the flusher
Old Mar 27, 2010 | 11:06 AM
scottfedm's Avatar
Thank you for the quick simple answer. Just what i needed. Im considering 20x9 up from with 20 offset and 20 x 10 in rear with 27 offset. Would you think these would clear brembos?
Old Mar 27, 2010 | 11:20 AM
JBF's Avatar
JBF
what wheels are they?
Old Mar 27, 2010 | 11:22 AM
LordFappington's Avatar
It depends on the design of the wheel for it to clear or not...
9 width with 20 offset will more than likely not sit flush. Neither will the 10 with 27...
I suggest you go 10 front and 11 back if you want to sit flush with those offsets. If those dont sit flush as youd like, do spacers.
Old Mar 27, 2010 | 11:28 AM
scottfedm's Avatar
im considering the exe konvex. There are a number of gs out there with them but i have yet to see one with brembos. This may be the reason. I would probably need spacers anyway.
Old Mar 27, 2010 | 11:35 AM
Charvey's Avatar
i am currently running 20x11 at ~+28 in the rear and its perfectly flush (i say approx because HRE doesnt disclose offsets and i took a rough measure) if youre looking at 10's a +20-+15 should work good
Old Mar 27, 2010 | 01:15 PM
eurodre's Avatar
you need to know what disk the wheels are in order to know if they clear brembos
Old Mar 27, 2010 | 01:28 PM
scottfedm's Avatar
what disk? thats new to me...what are you referring to?
Old Mar 27, 2010 | 01:34 PM
Disk is the sizing work wheels use. Doesnt apply to you.
Old Mar 27, 2010 | 03:45 PM
eurodre's Avatar
more companies other than work use disks to tell the bbk clearance...
Old Mar 27, 2010 | 04:52 PM
LiquidREVUP's Avatar
post pics when you get them!
Old Mar 27, 2010 | 05:10 PM
Disk sizing is referring to what really should be called x factor...
hdmark
Apr 29, 2019 04:31 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
RA102223
Intake & Exhaust
Jul 25, 2015 01:03 PM
