another will this wheel fit thread :(
Old Mar 30, 2010 | 10:26 AM
g35winnipeg's Avatar
hey guys im about to purchase some enkei rp03's today but it need to know it they'll fit first
19x8.5 and 19x9.5 Enkei RP03s with +22 offset all around
will it fit my 03 coupe with factory brembos?
and does anyone know how flush it will sit by chance?
Old Mar 30, 2010 | 10:37 AM
LordFappington's Avatar
wont sit flush by far, you need 10 in the front and 10.5 to sit flush with that offset.
Old Mar 30, 2010 | 10:42 AM
velomack's Avatar
Should clear brembo
Old Mar 30, 2010 | 05:08 PM
so if i want it to sit flush what spacers should i use all around about 10mm?
Old Mar 30, 2010 | 05:11 PM
no you need more than 25 to make it sit flush, and anything after 25 is not safe... soo get a wider wheel kthx.
Old Mar 30, 2010 | 05:12 PM
4DGS's Avatar
Flush or hella flush?
If they were my wheels, 20mm spacers front and rear.
But if you want them to just look good then 15mm will work.
Jackus, a 30mm spacer on that is going to poke....
Old Mar 30, 2010 | 05:15 PM
and without spacers how bad will it look?
i mean i dont want my wheels sticking out i just want them flush, i also dont want them sunken in too bad, but will it be worse then stock?
Old Mar 30, 2010 | 05:16 PM
4DGS's Avatar
Are you lowered yet?
Old Mar 30, 2010 | 05:19 PM
not lowered, sounds like im going to have to go with a different wheel
Old Mar 30, 2010 | 05:21 PM
Im slightly poking with 9.5/10.5 +17/+24
Old Mar 30, 2010 | 05:22 PM
4DGS's Avatar
Na man, you'll be fine with those wheels.
Do you plan on going lower? Every inch you lower your car basically subtract 8-10mm from your offset.
I suggest you go lower, but I tell everyone that.
STCLAIRWEST's Avatar
Im guessing your not lowered
Old Mar 30, 2010 | 05:25 PM
not lowered, i really want these wheels but i'm afraid it will look bad on a stock ride setup without spacers :/
Old Mar 30, 2010 | 05:26 PM
4DGS's Avatar
He's not lowered and I just looked at photos of his car, he's not poking.
You don't understand offsets very well.... In the thread where you shower of your car and you dad gfs car, someone immediately told you, drop and spacers.
OP buy some spacers, nothing wrong with em.
Old Mar 30, 2010 | 05:31 PM
so instead o a spacer i could go for a 1-2" drop and not run spacers and i will sit flush?
thats cool, i never really knew that thanks for the info!
