Did I reconnect the Cam Position sensors Wrong?
Old Mar 31, 2010 | 08:56 AM
jwrape's Avatar
Well during my engine swap I COULD have installed the Cam Position sensor plugs wrong. Reason I think so is the motor is running good, but just not as peppy as my old motor and when I plugged the connectors in, there is a black one and a green one. On the driverside, I plugged the Green one up on the outer most plug and the black on the inner most plug, on the passenger side they fit opposite - Black on the otter most plug and green on the inner. I think I have the passenger side backwards but just not sure cause it didn't seem to wanna fit.
Anyone know?
Old Mar 31, 2010 | 11:00 AM
Iamnotkento's Avatar
I thought they can only fit one way?
Old Mar 31, 2010 | 11:04 AM
jwrape's Avatar
That's what it seems happened. I just found it funny that they were unsemetrical. I went out to the car in the parking deck and tried to swap them and the wiring harness was too tight to swap them so I suppose they are supposed to be that way.
Old Mar 31, 2010 | 11:06 AM
jwrape's Avatar
I also found this connector disconnected while I was trying to swap the CPS plugs. This might be a problem ,but I just don't know where it goes.
Old Mar 31, 2010 | 11:12 AM
GreenGoblin's Avatar
The goblin resurrection
pretty sure it goes under the lower intake manifold
http://img.photobucket.com/albums/v1...5/IMG_0954.jpg
http://img.photobucket.com/albums/v1...5/IMG_0957.jpg
this area
Old Mar 31, 2010 | 11:14 AM
http://img.photobucket.com/albums/v1...5/IMG_0982.jpg
There should be a sensor some where in the middle of the valley if I remember correctly.
Old Mar 31, 2010 | 11:15 AM
bigc's Avatar
Wings Nation
lol, danny i was just about to IM you about that connector!
Freeman186
Sep 6, 2023 10:07 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
wuzz-upp
Oct 3, 2015 04:21 PM
n2fooz
Sep 4, 2015 07:46 PM
UT G35
Sep 3, 2015 03:58 PM
