Ticking Sound - Underneath Car... ???
Old Apr 7, 2010 | 12:29 AM
jaketuff's Avatar
Confused with a ticking sound underneath the car. It sounds like water turning to steam right away - flash boiling - and gives that siss siss siss sound for a few seconds.
No rain/wetness underneath. Coming from underneath the driver seat area under the car.... Is this a normal issue???
ANY HELP?
2005 AT Coupe 70k.
Thx
PB
Old Apr 7, 2010 | 12:36 AM
SxExCx's Avatar
Does it do it under hard acceleration?
May be an exhaust leak.
Old Apr 7, 2010 | 12:43 AM
jaketuff's Avatar
Honestly I don't beat on it. The sound comes on after some miles of driving and it's noticeable for a few moments after shutdown.... Like water searing on a pipe or something.
There are no foul (or sweet/coolant) odors. Underhood looks fine. Oil looks fine.
Will keep hunting. Really weird sound though, it also happens when driving in and out of throttle... it's consistent - not melodic...
Hmmmmmmmmmmmmmmmmmmmmmmmmmmmmm
Old Apr 7, 2010 | 01:02 AM
xxkylexx's Avatar
i get snap crackle pop every time i come home and get out of my car. sounds like the y-pipe cooling off to me. not sure if its the same thing you are describing through.
Old Apr 7, 2010 | 01:09 AM
jaketuff's Avatar
I think so. Sounds like exhaust 'crackling.' Just got the car, and not familiar with these idiosyncracies. (or the spelling of that word)
Old Apr 7, 2010 | 04:25 AM
jutn35's Avatar
G35 Coupe
metal influxing
Old Apr 7, 2010 | 07:15 AM
VQ Johnny's Avatar
I have the same noises after shutdown its just the metal of the exhaust contracting as it cools
Old Apr 7, 2010 | 11:24 AM
Sammy23's Avatar
does the car vibrate?
Old Apr 30, 2010 | 08:09 AM
sillyoldtayo's Avatar
my car does this too! It sounds like a drops of water hitting a hot pipe repeatedly. "tsss tsss tsss tsss.." Ive never heard it on any of my other rides. I am used to hearing the exhaust and other metal parts contracting as they cool but this sounds completely different. No leaks or anything unusual to report other than that noise though. No harm no foul? haha
Old Apr 30, 2010 | 08:54 AM
spinna001's Avatar
Normal
Old Apr 30, 2010 | 12:07 PM
elperuano's Avatar
Yea I heard this also which I think is normal. Heard it after I installed test pipes n hks. Never had a leak... Usually would happen at idle after some miles of driving. Its very faint though you'd have to REALLY listen for it.
Old Apr 30, 2010 | 12:12 PM
spinna001's Avatar
do you have a hiss. Mine hiss when i installed test pipes. If i gas it and when the rpms are coming down it hisses?
Old Apr 30, 2010 | 12:15 PM
elrooko's Avatar
Is your Air Conditioning on? This could be the water sweating off the refridgerent lines or the accumulator. The water drops off and may be hitting your exhaust manifold or the exhaust pipes. Try driving around with it off and see if it makes a difference.
Old Apr 30, 2010 | 12:16 PM
elperuano's Avatar
Well I HAD a hiss. It happened only for awhile n then went away. Never under load just at idle
Old May 2, 2010 | 10:22 AM
I never use the AC and i have the "tss...tss...tss" noise to Oh well if its normal were good
