Starting up Problem.
Old Apr 12, 2010 | 02:11 AM
jutn35's Avatar
G35 Coupe
Exclamation Starting up Problem.
I recently swapped out my INFINITI logo airbag cover for a Nissan one. I took it out the night before so it would be ready to swap out the next day. In the morning when i went to turn on my car , The RPM needle jumps to 2k then goes back to 0 and shuts off, sometimes it would catch itself before going to 0 and it would sound as if its struggling to keep the RPMs or ill have to gas it a little to keep the needle with high RPMs. I drove without the Airbag to LA to do the swap and after i did the swap it still did this. Did i do a no no ?
Any input would be appreciated
Old Apr 12, 2010 | 02:15 AM
fatlip's Avatar
maybe diconecct the battery and let it reset after its all back together?
Old Apr 12, 2010 | 02:18 AM
Pratt's Avatar
although its prob not your problem i had this happen to me alot when i had a cut in my intake tube
Old Apr 12, 2010 | 02:23 AM
jutn35's Avatar
G35 Coupe
this i will try tommorow bc i had to disconnect the Battery when taking out my airbag cover.
aiya ! i hope it isnt this
Old Apr 12, 2010 | 09:00 AM
bina12834's Avatar
subscribed because im about to do the swap too.
Old Apr 12, 2010 | 03:58 PM
jutn35's Avatar
G35 Coupe
i called my mechanic up and told him the story, what he said was that the computer has to relearn the throttle process or something. Saying that a couple mins with a scanner will reboot the computer and itll be fine. its ok to drive with it too.
thanks guys
chinee
Jun 10, 2024 07:48 PM
mike730
Jan 12, 2018 04:25 PM
All G'd Up
Aug 29, 2015 12:40 AM
G35CO
Aug 25, 2015 02:00 PM
chinee
Aug 8, 2015 10:11 AM
