6speed g35 owners
Old Apr 16, 2010 | 07:02 PM
  #31
Minheeeme's Avatar
None
Old Apr 16, 2010 | 07:08 PM
  #32
spankey167's Avatar
Just change your tranny fluid and upgrade to something like Redline. Mine is still notchy, but a lot better with the Redline.
Old Apr 16, 2010 | 08:37 PM
  #33
saywat?'s Avatar
shift from 1-2 at or under 1k rpm and should shift smooth.
Old Apr 16, 2010 | 09:08 PM
  #34
STILLENDoutG35's Avatar
Thanks for the suggestion man! So yeah we need 3 quarts for our tranny right?
Old Apr 17, 2010 | 01:00 AM
  #35
G35CDriver's Avatar
Mine shifts just fine. The only problem I was having last summer was the clutch pedal was sticking 3/4s of the way out. Fixed though. It does get a little touchy when in heavy traffic on really hot days, I can feel that it does not like the traffic situation. lol
Old Apr 17, 2010 | 02:49 AM
  #36
code2424's Avatar
Only problems I have are 5th gear sometimes grinds usually in high rpms. I will change transmission fluid hopefully it will go away.
Old Apr 17, 2010 | 09:03 AM
  #37
SpcCain's Avatar
You get used to the clutch it is is a bitch. Here is a tip for smooth gear changes, dont fully depress the clutch, depress it a little past the engagement point instead of depressing it all the way. I use this method and I get very smooth gear changes.
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
laksjd84
Jul 24, 2015 05:12 PM
vstypicals
Jul 20, 2015 10:55 PM
Chattzx
Jul 17, 2015 11:23 AM
