i need to change oil
View Poll Results: which Synthetic oil brand should i go with
castrol
34
31.78%
royal purple
21
19.63%
mobil
52
48.60%
Voters: 107. You may not vote on this poll
Apr 24, 2010 | 08:39 AM
  #31
mobil 1.
Reply 0
Apr 24, 2010 | 10:35 AM
  #32
Realistically any oil is fine, as long as you change it in regular intervals. (I use Mobil 1)
Reply 0
Apr 24, 2010 | 12:45 PM
  #33
Ive been using kendall for some time and its been holding up better than Mobile 1, color was yellower after 4k miles
Reply 0
Apr 24, 2010 | 03:06 PM
  #34
Quote: That must be why the label on the Mobil 1 containers say 100% Full Synthetic....
Gary
It's a "full synthetic" by the definition that the oil industry uses, but it's a Class III synthetic. That basically just means it's not a synthetic blend... but doesn't mean that it's an elite quality or Class IV/V synthetic.
Reply 0
Apr 24, 2010 | 05:23 PM
  #35
Quote: German Castrol 0W30... the only oil I use in my G35.
You can pretty much only buy it at Auto Zone, and it's a real Full Synthetic, unlike regular Castrol Syntec, Mobil 1 and most of the other "synthetic" oils that you can buy off the shelf.
+ 1,000,000 on that.
After exensive research I came to the exact same conclusion. They put it on sale at Auto Zone including a high quality oil filter for about 30 bucks. I have stocked up lots of it.
Reply 0
Apr 24, 2010 | 09:39 PM
  #36
So, how often should you change your oil if using German Castrol?
thanks
Reply 0
Apr 24, 2010 | 10:13 PM
  #37
Quote: So, how often should you change your oil if using German Castrol?
thanks
I do mine at about 3700 miles. I'm sure I could go a LOT longer, but there's no need to push it. I also do a lot of short trips and back roads driving, about 6 miles each way to work... those are a lot rougher on your motor oil than longer trips and highway miles.
Reply 0
Apr 24, 2010 | 10:49 PM
  #38
Quote: this was pulled off of my350. Green means better than one standard deviation, red means worse. Notice how Mobil 1 has several reds, while Castrol is mostly green.
Quote: ^ take a look at these threads.
https://g35driver.com/forums/g-spot/...v-withuoa.html
After seeing the above
I went with Castrol Syntec it always goes on sale and protects well. Been running it since my first oil change when I got my car.
Reply 0
Apr 25, 2010 | 01:24 AM
  #39
^ good call. I'm a scientist by profession, and for me, empirical evidence will always beat out subjective ones.
Reply 0
Apr 26, 2010 | 10:50 PM
  #40
What is Mobile 1 Extended Performance, Class III still? Its rated at 15,000 miles which I would never try.
Reply 0
Apr 27, 2010 | 10:50 AM
  #41
now im deciding between mobil 1 and castrol XD
Reply 0
Apr 28, 2010 | 09:43 PM
  #42
Weekly bump
Reply 0
Apr 29, 2010 | 10:40 AM
  #43
Castrol Syntec or Mobil 1
Reply 0
Apr 29, 2010 | 11:23 AM
  #44
thanks
I do every 3,333 on my turbo Subaru only because it's a highly modified application.
I also used to run it on a honda civic and had several UOA's done by Blackstone. The first one I sent them at 3,500, they said it had a lot more life and to shoot for 5K next time. I sent them the oil after 5K and they told me to shoot for 7500 miles and noted that if that looked good to them after that, I might want to try for 10K. I just stuck with the 7500 as that was good enough me.
I plan on changing it every 5K in the G.
Reply 0
Apr 29, 2010 | 01:02 PM
  #45
Mobile 1 full synthetic
Reply 0
