5AT please Chime in.
Old Apr 29, 2010 | 10:28 AM
spinna001's Avatar
I think i might be having tranny issues i dunno. I checked my fluid, it is at the correct level and a beautiful clear pink color. Ok when i am on the highway if i am at speeds of 75mph in D and if i shift it over into Manual Mode it will be in 4th is this normal? Also for some reason when i go through the gears n manual from 4th to 5th i barely feel the shift. Please help me.
Old Apr 29, 2010 | 10:31 AM
Hotdawwgman's Avatar
Normal... Dont worry about it! My 04 Sedan does this!
Old Apr 29, 2010 | 10:36 AM
bknewtype's Avatar
its normal. i believe 5th gear is just for "cruising", so driving on 4th is normal.
Old Apr 29, 2010 | 10:39 AM
spinna001's Avatar
thanks guys i am getting worried. I really do not want to go back to stock and then go to stealership.
Old Apr 29, 2010 | 10:53 AM
NachoCheese's Avatar
Yeah, for some reason when you switch from D to MM, it'll put you in a gear lower than you think you should be in, lol. I don't ever put mine in D though, so I don't know much about it.
Old Apr 29, 2010 | 11:01 AM
SkylineGTR2789's Avatar
MM all day for me .. I never use D
Old Apr 29, 2010 | 11:03 AM
bknewtype's Avatar
isnt it bad for the transmission to always use MM?
Old Apr 29, 2010 | 11:04 AM
goodmank's Avatar
When you shift from auto to manumatic it automatically downshifts. And normally you shouldn't feel the shift from 4th to 5th unless you are shifting above 4500 rpms from 4th to 5th.
Old Apr 29, 2010 | 11:11 AM
Tollboothwilley's Avatar
+10
Unless you put in the transgo shiftkit the 4-5 shift is pretty hard to notice. After the shift kit its much more noticeable over 3500 rpms.
Old Apr 29, 2010 | 11:12 AM
No its perfectly fine... As long as you aren't taking it to Redline every single time, you should be fine... These are the same Transmissions that were used in the Q45... They can take more power very easily...
Old Apr 29, 2010 | 11:28 AM
PerpetualVisitor's Avatar
Its fine. I shift to MM on highways only (i'm too lazy to use mm in local los angeles traffic. jeebus i'm glad i didn't go 6mt). I prefer it to go to 4, since I usually remember to mm it when I'm trying to pass cars anyway.
on another note, forgot that i switched the + and the - on it and I downshifted and made my engine roar on local streets. i swear, people were looking at me moving at like 10mph but screaming bloody mary.
Old Apr 29, 2010 | 11:32 AM
bknewtype's Avatar
what you mean switch? you mean push back for up shift, and up for downshift?
i remember when i tried mm for the first time. i played too much initial d arcade games, so i thought pulling back ont he shifter will make it shift up, and i kept doing that to my g, and i was like wtf why is my engine screaming so loud but not going faster lol
Old Apr 29, 2010 | 11:42 AM
spinna001's Avatar
Thanks guys for all the advice. I think i need to lay off the trees.
Old Apr 29, 2010 | 12:07 PM
gck's Avatar
gck
you must have a very bad MPG
Old Apr 29, 2010 | 12:08 PM
is 18.5 - 19 mpg in the city bad?
