Traction Rod & Camber Arm help decide (I have done my research)
Old May 8, 2010 | 05:22 AM
alex_b's Avatar
Smile Traction Rod & Camber Arm help decide (I have done my research)
In my previous thread I had stated that both my camber arm and my traction rod were bent on my rear passenger side and needed to be replaced. So I have decided to go with ichiba camber arms with toe bolts.
The only problem I have is deciding which traction rod (traction arm) to go with since I have been reading here that adjustability (although i will not be adjusting it just need a replacement since mins is bent) of the traction rod with mess up the geometry and the caster of the rear upper and lower mount of the rear. Im going for the aggressive streched look some time in the future.
Ps: car is stock height right now
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
2_Liter_Turbo
Jan 19, 2018 01:48 AM
StreetStandard
Suspension-Vendor
Jan 18, 2016 03:36 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
