How to take apart the interior door?
Old May 19, 2010 | 11:30 PM
changeover's Avatar
There is this insane rattle that happens usually when I brake but can happen other times and Im almost positive that it is coming from my door. Whats the best way to take apart the door so I can try to fix wtf is rattling. Driving me insane!!!! Doesnt help I have crazy tire roar either....gotta fix that too haha
Old May 19, 2010 | 11:37 PM
boz35coupe's Avatar
pop out the little cover behind the handle there is a screw in there,
then take of the silver trim on the grip part, there are two more screws in there, once you have all the screws off, grip the bottom where the plastic meets metal and slowly pry it apart, once the tabs come out lift up and you should be all set. good luck
Old May 19, 2010 | 11:39 PM
changeover's Avatar
sweet man. This is gonna be my project for Sunday. Thank you!
Old May 19, 2010 | 11:44 PM
boz35coupe's Avatar
good luck try not to lose anything haha
Old May 19, 2010 | 11:45 PM
changeover's Avatar
haha oh boy I hope not. I tend to do that alot with this stuff, drop a nut or a bolt somewhere where I cant get to it. Thanks again!
Old May 20, 2010 | 02:43 AM
Footballmania32's Avatar
Make sure you wrap your flathead screwdriver in electrical tape or something to prevent damaging any interior trim. Also, the first thing you may want to do is pop off the window/lock control pad. The best way I've found for getting it out is to use a credit card or drivers license to slide between the door panel and the window/lock piece. After that pull it out and use a screwdriver to detach the harness. Same goes for the courtesy light under the door, but that one you have to work on after you take the entire door panel off. A extra set of hands helps for that step. There is a DIY thread on here too with pictures if you need more help. Good luck!
-Sean
Old May 20, 2010 | 10:00 AM
changeover's Avatar
-Sean
Cool man, thanks for the tips!
Dallsinghjr1
Sep 17, 2023 11:25 AM
Picture Share
Feb 4, 2018 12:41 PM
prinny
Nov 22, 2015 11:07 PM
TNRocker
Sep 21, 2015 08:36 AM
