Different tire pressures (noob)
May 27, 2010 | 01:10 AM
so i just bought a 06 g used from a private owner and the tires he put on them had different tire pressures (the 2 in the front were different from the back).
however they all measured at about 36 psi when the max psi in the front tires is 51 and in the rear its 44. is the tire pressure supposed to be the same or different? any suggestions on tire pressure?
Reply 0
May 27, 2010 | 03:18 AM
Tire pressure is supposed to correlate on the sticker located in the driver's doorjamb.
Reply 0
May 27, 2010 | 03:20 AM
I put 35psi on all 4 tires. Some people put higher pressure on the fronts since it is heavier than the rear.
Reply 0
