Need Help! Weird problem with driver door and windows
Old May 31, 2010 | 01:41 PM
trunks333's Avatar
Something weird is happening to my car.
When i close my driver side door, the driver side window does not raise or drop the 1/2 inch from the top. When this happens the door locks or the passenger side window does not work.
In order for it to start working again, i would have to open the driver side door half way, then the locks and passenger side windows work! I am so confused.
Is there something that activates when the door is half way open??
I do not think its a short or loose wire because yesterday and opened/closed the door 100 times to replicate the problem, and everything worked fine. This problem happens randomly. Maybe once every 2-3 days. If it was a short or loose connection, the would happen more often.
Could it be that the window switch can be bad? I do not even understand why everything works again when i open the door half way.
Old Aug 2, 2010 | 10:39 AM
randy021186's Avatar
bump i have the same problem with the window
mike730
Jan 12, 2018 04:25 PM
will091195
Jul 27, 2015 09:19 PM
apintojr
Jul 23, 2015 10:52 AM
attarday
Jul 15, 2015 04:03 PM
