Shift light flashes at 3.5 rpms?
Old Jun 3, 2010 | 08:39 PM
Phu's Avatar
Phu
So about a month ago my service engine soon light went on for about 3 days and turned off. Hasn't lit up since, at the same time the ses light went on, the shift light started flashing after 3 1\2 thousand rpms. Its not suppose to flash until red line. For all the 6MT drivers, its a small sqaure red light on the dash underneath the REV light. Had the car scanned, mechanic said checked out fine. The car runs fine, its just annoying as hell. Anybody else had this problem?
Old Jun 3, 2010 | 09:45 PM
tEh d0ct0r's Avatar
Never had that happen. Did you try changing the setting and then putting it back to where you want it?
Old Jun 3, 2010 | 09:53 PM
GOWAD's Avatar
You can change the set point for the light by pressing the trip reset button a couple of times 'till you see the shift light setting, then hold it down until you get to your desired rev.
Old Jun 3, 2010 | 11:16 PM
gck's Avatar
gck
that was a fast answer
Old Jun 5, 2010 | 02:37 AM
junCakes's Avatar
Originally Posted by gowad
you can change the set point for the light by pressing the trip reset button a couple of times 'till you see the shift light setting, then hold it down until you get to your desired rev.
+1.
Old Jun 5, 2010 | 01:27 PM
sillyoldtayo's Avatar
mine flashes at 3500rpm as well. i set the shift light to come on at 4k and it comes on slightly early so you dont end up passing that point.
real simple, press the trip odometer until it reads something other than trip A or trip B and then hold down the trip odometer button, the numbers will flash, at that point you just press the button until you get to the rpm you want. once you select the one you want just let it sit for a second and it will stop flashing and you will have changed your shift light setting. mine came with a factory setting of 8000
Old Jun 5, 2010 | 01:42 PM
g-adabout's Avatar
wow, what happened to reading the manual?
Old Jun 5, 2010 | 02:32 PM
haha^ I like to just assume that the OP's ask these questions because they dont have a manual haah
Luisgalvan33
Jul 19, 2018 08:16 PM
03sedang35
Aug 29, 2015 07:56 PM
Herbbie Hablib
Forced Induction
Aug 11, 2015 06:22 PM
ghost_g35
Aug 7, 2015 10:31 AM
EliteG
Engine - Electrical
Aug 5, 2015 07:50 PM
