Help - Cam Sensor?
Old Jun 6, 2010 | 10:43 PM
dp_PRIME's Avatar
Help - Cam Sensor?
Hey, just yesterday i tried to start my car and there was a good 5 second delay before it actually started. Then all the lights started showing up...from "Service Engine Soon" to "VDC off" to "Slip"...etc.
I initially thought it was a spark plug or the starter, but neither of them are the problem. My friend said it happened to him and it was a malfunction in the Cam Sensor....could this be? I did not see how a problem in the Cam Sensor would cause a delay in the start of the car, but if u guys think this is possible let me know. Thanks.
Old Jun 6, 2010 | 10:52 PM
Eric@TCGMiami's Avatar
Check what the code is..
It could be your alternator is failing.
Old Jun 6, 2010 | 11:18 PM
kvangil's Avatar
Yes, one of your camshaft position sensors is bad. Get the code checked to see which one. It cost me $350 at Nissan to have it replaced....
Old Jun 6, 2010 | 11:24 PM
How can you come to the conclusion?
Does the car misfire? Is it sputtering?
He didnt state any of that just "his friend said so" I like to diagnose to be 100% sure rather than guessing.
Old Jun 6, 2010 | 11:28 PM
tonke73's Avatar
I had a cam sensor go bad in my 300zx. The car started right up, but died after a few seconds. The best thing is to hook it up to an OBDII and get the code.
Old Jul 7, 2010 | 03:33 PM
dj codeman's Avatar
i just had to replace all my cam and crank sensors.... $400 done by the stealership
Old Jul 7, 2010 | 05:32 PM
spoolinupblue's Avatar
samething happened to mine OP.
I did pull the code and mine was the cam position sensor. I replaced both for like $80 and about 1 hour of my time. Reset ECU and back on the road I went.
You should pull the code though.
Old Jul 7, 2010 | 05:41 PM
06g35meister's Avatar
exact same thing happened to me, its either one of the 4 cam sensors OR the crank angle sensor. Should be ~60 to replace and you can get to it Kinda easily, especially the Crank A.S., id say its a 3/10 on the difficulty scale
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
KallDay86
Jan 8, 2016 12:42 AM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
vamarris
Sep 26, 2015 12:56 PM
