Spc camber kit help!!!
Old Jun 11, 2010 | 03:05 AM
G35_REDLINE's Avatar
i tried to install SPC front camber kit on other day, and i ran into one problem. i cant get the black brushing on my OEM camber, so i went to the dealer ordered 2 of those brushing, and some how the one i got is not rubber but its metal and it to large for the spc camber kit. do anyone how to take off the rubber brushing on my oem camber, or the correct parts number that i can order them? anyone run to this problem?
i found this: https://g35driver.com/forums/brakes-...tallation.html
Attached Thumbnails Spc camber kit help!!!-titan-front-shock-assy-parts.jpg   Spc camber kit help!!!-imag0048.jpg   Spc camber kit help!!!-imag0049.jpg
Old Jun 11, 2010 | 06:50 AM
fatlip's Avatar
I just did mine a few hours ago. We put it in a vise and wedged a large chisel in there and hammered the **** out of it. Be sure to leave the nut on the ball joint so when the cone flies off it still be there.
Old Jun 11, 2010 | 10:28 AM
Deezflip's Avatar
rent a heavy duty joint or pulley puller from the auto store. They're usually free to rent but with a deposit that you'll get back when returning the tool. The one I used was a 3 jaw puller in which you can remove one of the jaws to make it a two jaw puller.
Old Jun 11, 2010 | 12:18 PM
fatlip's Avatar
Or hammer the **** out of it.
Old Jun 11, 2010 | 12:21 PM
JBF's Avatar
JBF
why is that drawing for a titan?
Old Jun 11, 2010 | 10:10 PM
i already did that, and that damn thing wont come off.
Old Jun 12, 2010 | 12:41 AM
fatlip's Avatar
Set it down on some wood. Wedge a chisel in there and whack away. The bigger the chisel the better.
Old Jun 12, 2010 | 01:30 AM
G35xChicago's Avatar
+1 on the Claw, this is the only thing that worked for me after hours of struggle!
Old Jun 14, 2010 | 08:34 PM
THANK YA, i just got my spc front camber kit install now, i went to auto rent a Claw, and finally that brushing came off. SO thank for ya help.
Old Jun 14, 2010 | 11:53 PM
walshtj's Avatar
Hahha that is a Titan.
Old Sep 16, 2010 | 06:35 PM
nsp106's Avatar
Where did you buy the ball seat bushing from?
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
boostelevator
Engine - Power Adders
Sep 9, 2015 05:56 PM
jsimonk
Steering & Suspension
Sep 2, 2015 03:07 PM
