rattle noise from pass side door
Old Jun 16, 2010 | 12:38 AM
changz8's Avatar
i need help to fix my pass side door panel, when hit some little bump on the road, my right side door has rattle noise, so i need help to make the noise goes away, need help thanks!
Old Jun 16, 2010 | 04:13 PM
radzguy's Avatar
I recently had a wicked rattle which I thought was coming from the passenger door...mostly when going over bumbs. After tearing the door apart and resetting my aftermarket component speakers, I took it to the dealer and it turned out to be bad tie rods. $1150 to repair no less!
Old Jun 16, 2010 | 04:19 PM
MDR G35C's Avatar
Mine always rattles. Its a G
Old Jun 16, 2010 | 04:32 PM
idrive_MD's Avatar
take the panel off and tighten the inner door panel, its metal and has like 20-bolts on it. mine did the same thing.
Old Jun 16, 2010 | 10:41 PM
changz8's Avatar
i just found out today, it was the pass seat making the noise, now i need to fix this problem? but how?
Old Jun 17, 2010 | 07:44 AM
scrapiron7's Avatar
I've had a bad driver side rattle since the dealer replaced the window motor. I might have to take it apart and see if something needs to be tightened.
Old Jun 17, 2010 | 08:41 AM
xxkylexx's Avatar
our g's tend to have lots of rattles. its annoying.
Old Jun 17, 2010 | 09:37 AM
gary c's Avatar
Ouch, damn radzguy that hurts! You could have paid 1/3 less for the same service at an independent brake/alignment shop that deals with suspension issues every day. We see threads like this all the time, find a shop you trust that doesn't have Infiniti written on the building....you'll be $ ahead!
Gary
Old Jun 17, 2010 | 09:38 AM
G35Lopez's Avatar
Sometimes the obvious is overlooked, for me it was the passenger seat belt bracket vibrating and hitting the door panel.
Old Jun 17, 2010 | 11:49 AM
izeroi's Avatar
Tell me about it. There's rattling in my dash and it sounds like two gerbils are running around back there.
rezendvous420
May 31, 2020 01:26 PM
xluke
Jul 30, 2016 01:48 PM
tiguy99
Mar 1, 2016 11:42 AM
apintojr
Jul 23, 2015 10:52 AM
emorehs
Jul 17, 2015 09:45 AM
