Catalytic converter
Old Jun 23, 2010 | 11:16 AM
GpIronKid's Avatar
Catalytic converter
i plan on removing my catalytic converter with a strait pipe is the oxygen sensor on the catalytic converter? or will i be able to take it off no problem without a code showing up?
Old Jun 23, 2010 | 02:11 PM
atrudeau's Avatar
There is and o2 sensor in the middle of the cat. If your new strait pipe doesn't have a spot to put the sensor then you will throw a check engine light because of the missing sensor.
Old Jun 23, 2010 | 02:13 PM
Calvin's Avatar
Overglorified Altima
All test pipes made for this car have slots for the o2 sensors. But some will require non-foulers to prevent the CEL.
Old Jun 23, 2010 | 02:21 PM
istan's Avatar
Since it sounds like you're getting the pipes fabed up to do this, just have them weld a bung onto the pipe but also build in some space between where the O2 sensor would attach and the pipe. IE, extend it out some.
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
JustinMKN1
Sep 18, 2015 03:40 PM
G35-2004-mt6
Sep 11, 2015 04:16 PM
Hawk196
Sep 10, 2015 10:37 AM
