Need help: Just replaced battery and car stalling occasionally
Hi all.
After 97000 miles I finally had to replace my stock battery. Over a short period of time it began starting slower and slower so I bought a new battery (650 cranking amps/800 cold cranking amps) from Costco.
I think I did everything correct: remove (-) terminal first, re-connected (-) terminal last per my Nissan mechanics instructions. He didn't mention any other things I needed to do.
So, after the install I fire her up and she roars to life and I figure everything is good. Start sounds much stronger than with the old battery.
On the next day I went out to lunch and when I came out I went to start and it started fine but the rmps just gradually/smoothly fell to zero. No bad noises or anything else, just almost sounded like when you shut the car off normally. It was a bit hard to re-start as well. Since then it probably happens once a day.
Every time this has happened I have had to give it some gas to keep it from stalling and then it is fine.
So, what's going on? What little Nissan gremlin did I run into on this install?
Thanks!
Thanks!
Hi all.
Thanks!
Thanks!
rezendvous420
May 31, 2020 01:26 PM
