clicking noise from front passenger side. HELP!
Old Jul 2, 2010 | 01:28 AM
sk8bo4rdv's Avatar
hey guys so just a few days back i started hearing this annoying clicking noise from my front passenger side. it just sounds like something clicking and it gets faster as i drive faster. i tired inspecting what the problem could be and came up with nothing and am here asking you guys what it could be. anyone know or have this problem before?
i replaced my brake pads this january so i know they arent worn. my rotors might be worn but probably not. besides that what else should i check for.
thanks for all the help
Old Jul 2, 2010 | 04:27 AM
jutn35's Avatar
G35 Coupe
i had this problem , buuuuuuut one of the bolts to my engine weather gaurd came out an it started to drag on the road.
Old Jul 2, 2010 | 04:31 AM
Tabris's Avatar
I've had a similar sound, I think it was just a rock stuck in one of the tires.. the clicking would go faster as i did. Then the rock must have fell out, and it stopped
Old Jul 2, 2010 | 09:50 AM
obsidianvq35's Avatar
I have this same problem but on the driver front...idk what it is and can't figure it out. Also, if anyone can help out with another issue I'm currently having in addition to the clicking noise..when the left side of the car drives over uneven payment/bumps and the right side is fine..i hear this metal sound, i wouldn't say its a banging sound but def metal touching or taping together or something
Old Jul 2, 2010 | 04:51 PM
sk8bo4rdv's Avatar
ok guys so i checked out what the problem could be again today and guess what? it was a small rock stuck on the backside of the rotor..hahaha so i knocked it loose and viola noise disappeared.. cant believe i missed the rock the first time
sk8bo4rdv's Avatar
sounds like bearing or a arm joint going bad
Old Jul 2, 2010 | 06:05 PM
How do i figure out what the problem is? and what bearing?
Old Jul 2, 2010 | 06:16 PM
sk8bo4rdv's Avatar
the bearing that spins ur wheel. when u jack up the car try wiggling the wheel back and forth, left to right and see if it moves/ has any give. if it has any movement u have a bad bearing if u dont then try looking at the arms/ bushings
Old Jul 2, 2010 | 06:24 PM
Calvin's Avatar
Overglorified Altima
I have this in the passenger front, too. Comes and goes. I'll check for rocks.
Old Jul 2, 2010 | 06:27 PM
sk8bo4rdv's Avatar
^^ check for rocks calvin.. i couldnt believe it either even the smallest rock stuck behind the rotor causes noise
Old Jul 3, 2010 | 05:01 AM
Tabris's Avatar
Rock! Knew it!
I did experience the same sound on an older car I owned as well. Turns out I had a nail sticking out of one of my tires *sigh*
Old Jul 4, 2010 | 03:39 AM
muellerG21's Avatar
rock in the rotors - thats a first for me but ive heard of much stranger things lol and see quiet a few too! def better than replacing parts!
rezendvous420
May 31, 2020 01:26 PM
rping
Jul 26, 2015 09:53 PM
Bean_VQ35DE
Jul 22, 2015 07:06 PM
papo020
Jul 17, 2015 10:30 PM
