Key Fob Question Please!
Old Jul 6, 2010 | 04:35 PM
DT35G's Avatar
I have an 05 coupe. If I buy an 07 up smart key fob, can I use it for my locks and trunk purposes. I know it wont start my car or autimatically unlock my doors, but is it still programable for the other functions. Thanks
Old Nov 28, 2010 | 10:46 PM
Osa713's Avatar
I have the same question. I can't believe no one answered this with over 100 views smh.
Old Nov 29, 2010 | 12:01 AM
herrschaft's Avatar
As long as the frequency is programmed I don't see why it wouldn't work. Stealerships like to sell stuff, I'm sure they would be able to answer your question.
Old Nov 29, 2010 | 12:23 AM
speedracerg35's Avatar
No. They are on different frequencies and aren't programmed the same way.
Old Nov 29, 2010 | 08:44 AM
DT35G's Avatar
^^ I had called the stealership and they told me it couldnt be done. They also told me that if I used a Nissan Key Fob that looks the same as ours it couldnt be programmed to our cars. Well it can be, I did it. As for the 07 and up keyfob, I havent been able to figure out a way to program it yet so I did the MOD instead.
Old Nov 30, 2010 | 12:57 AM
yeah, the nissan key is just a different case with the same guts. the ikey seems to need a programming module that hooks into the obdII to mate with the car.
Old Nov 30, 2010 | 09:38 AM
DT35G's Avatar
Either way i have been modding them now. I successfully completed a bunch of them so if anyone wants it done for them, let me know. Ill make a good deal for it.
Old Jan 3, 2011 | 05:02 AM
Maxad's Avatar
Hi guys
I have a question about the keyfob.
This is my remote controll for the car with the key, is this the keyfob ? Can i program it so it will work as a keyless entry ? What else can i do with this ?
Old Jan 3, 2011 | 05:05 AM
Maxad's Avatar
I also find this for the keyfob ! Would this work on my car ?
1.Sit in car and lock the doors(all of them)
2.Insert the key into the ignition 6 times within 15 seconds(important to be in 15 seconds)
3. lights(Hazard) should flash
4.Put key back into the ignition & turn to Accessory
5.Press the master door lock (on drivers door arm rest) unlock/lock
6.Hit the lock button on the remote
7.Hazards should flash
8.Pull key out and open the drivers door and then close it
9.It should be set
Make sure you keep these steps and see the hazard light flashing.
I have a G35 Coupe 6MT from 2006
Old Jan 3, 2011 | 07:14 AM
atmel101's Avatar
Yup looks right.
9.It should be set
Old Jan 3, 2011 | 07:16 AM
atmel101's Avatar
What exactly have you been modding?
To answer the original question 07+ will not work.
Old Jan 3, 2011 | 08:55 AM
Maxad's Avatar
what will be happend with that setup in my car ? I mean what would exaktly happend if i do that ?
Old Jan 3, 2011 | 10:19 AM
DT35G's Avatar
Been taking the old ugly keyfob and modding it so the board can work in the newer style one. It wont have keyless entry but it wont look like a piece of **** anymore.
WHAT THIS MOD IS: taking the old ugly keyfob, tracing and modifying the circuit board to fit and work inside the new style keyfob that comes on the 07 and up vehicles.
Do your research people, there is plenty of reading on this mod out there!
Old Jan 24, 2011 | 12:26 PM
P10 WRC's Avatar
will a four button fob work if my car came with a three button fob? i have an 06 sedan 6MT
Old Jan 24, 2011 | 04:46 PM
felixsc300's Avatar
I have the four-button 07+ Intelligent Key remote that's been retrofitted with the guys from the plasticky key fob on the earlier years. A member did it for me on the forums, but not sure if he still offers that service. Key itself was $35, the service was $50. Total $85 with a one-week turnaround time, so you'll be keyless-entryless during that time.
In other words, if you just buy the key fob it will not work, but if you're willing to do a bit of soldering (or hire someone, like I did) then you can integrate both pieces into one.
