How Do I Remove Stock Grill
Old Jul 15, 2010 | 09:19 PM
DT35G's Avatar
Hey guys, I removed all the plastic clips on the top but I cant seem to figure out where else its being held to the bumper? Is there a DIY on here or a thread that shows how its done so I dont F nothin up?
Old Jul 15, 2010 | 09:31 PM
WhosRich's Avatar
Theres a couple tabs on the bottom that you need to "un-hook"
Old Jul 15, 2010 | 09:34 PM
gary c's Avatar
With your posts I'd expect for you to be more knowledgable here in DRIVER. Just do a SEARCH using the topic GRILLE INSTALL, there are several so you have a choices.
Gary
Old Jul 15, 2010 | 09:39 PM
dukehotty's Avatar
I had the same problem. Search the DIY section. There are some great pics and step by step instructions!
Old Jul 15, 2010 | 09:54 PM
bigc's Avatar
Wings Nation
after you remove the 4 pop rivets, look at the far end of the grill (left or right, doesn't matter) where it meets the core support. there's a tab back there that snaps into the core support. pull the end of the grill forward while pressing the tab with flathead screwdriver. it should slide right out (the clamps on the bottom don't do much). the opposite end of the grill will usually be loose enough by this point that you don't need a screwdriver to release the tab.
Old Jul 15, 2010 | 11:00 PM
walshtj's Avatar
^ +1, there are clips underneath that are a lil difficult to get to.
Old Jul 16, 2010 | 12:43 PM
DT35G's Avatar
I figured it out. It was simpler than I thouhgt, I was looking for something complicated instead of what was right in front of me. Thanks though guys
Old Jul 16, 2010 | 12:49 PM
gmotion04's Avatar
use a long flat head screwdriver to get to the two square shaped plastic pieces to turn them that was the biggest pain for me because i couldn't find the right tool for it
skippyG
Jan 25, 2016 01:18 PM
propho
Audio/Video/Electronics
Aug 27, 2015 04:56 PM
realtalk21
Jul 20, 2015 09:07 AM
