Engine shakes - anyone know WT* is wrong ?
Old Jul 21, 2010 | 06:38 PM
cccp.spb's Avatar
I've got 03 G35 coupe AT with 90K miles
When the car is in Park, Neutral or stopped at the light - engine shakes (rpms are standing still tho) and those shakes are uneven...
shake... 2 sec interval... shake.... 1 sec.. shake.... 5 sec.... shake.... 1 sec... shake... 1 sec...
you can feel it in the steering wheel and even with your a** sitting in the seat....
just driving me nutz...
at first I thought something is wrong with the engine.... but I checked - everything seems ok...
anyone else has this ?
Old Jul 21, 2010 | 08:18 PM
Inter_America's Avatar
hmm....have you been hammering your car? im thinking maybe one of your engine mounts is loose if you say the engine itself is fine.
Old Jul 21, 2010 | 08:21 PM
the_sedan's Avatar
im assuming no engine light on? sounds like a miss to me.....like a coil prolly?
Old Jul 21, 2010 | 09:00 PM
no, i dont think it's a miss, the engine light will most likely come up if it was a miss.
Old Jul 21, 2010 | 10:40 PM
biggz786786's Avatar
sounds like a loose or worn or torn engine mount
raise your hood and put your car in park, then put in reverse, then drive, then back to park, if it shakes violently then chances are its an engine mount
replace it, then get an engine damper, it will slightly help with the life of your new and old mounts, also turns that turning momentum into forward momentum
Old Jul 22, 2010 | 09:53 AM
spoolinupblue's Avatar
Sounds like a mount to me. As long as the engine seems fine.
Old Jul 22, 2010 | 10:03 AM
Tikiman12's Avatar
agreed motor mount, even if its not broken they will wear out
Old Jul 22, 2010 | 11:24 AM
cccp.spb's Avatar
No I haven't, but I just got it a couple of months ago and the previous driver could probably do that....
Ok, I'll check the mounts...
Old Jul 22, 2010 | 11:30 AM
cccp.spb's Avatar
momentum
Checked - absolutely normal shakes/movements
nothing unusual...
Usually when mounts worn, the engine shakes constantly. In my case it get little "jerks" with interval from 0.5 to 5 seconds. However on the colds engine there are no shakes (rpm slightly higher).
Could it be MAF sensor ? Or injectors?
Almost seems like the engine gets uneven mix of air and fuel...
Old Jul 22, 2010 | 11:48 AM
rasetsu's Avatar
maybe idle control issue...throttle body could be dirty
Old Jul 22, 2010 | 12:05 PM
cccp.spb's Avatar
How do I clean it ?
Thanks
Terry_G35
May 9, 2020 01:39 AM
linedr89
Aug 17, 2015 05:11 PM
ghost_g35
Aug 7, 2015 10:31 AM
Terry_G35
Aug 4, 2015 02:38 PM
ClwMike
Jul 23, 2015 12:55 PM
