Clutch pedal sticking
Old Aug 1, 2010 | 02:14 PM
DrMax's Avatar
I know there is already some post about that...
I have a 06 6MT G35 with 60 000KM (not miles) on it
Here's what happen... I was going to do a little friendly race with a STi so ive rev my car at 3k rpm and finally dump the clutch. But after a sec i realised that my clutch pedal was sticking and didnt want to come back ( 2nd time this happen ) so i pumped the pedal until it was ok. After that it start to smell like burned clutch for sure
Ive also notice that my clutch is damaged a little bit...i can feel the pedal is not as stiff than it was.
My car is still under powertrain warranty and under bumper to bumper warranty i think...so will Nissan/Infiniti will replace some parts or fix the problem?
Also do i should remove my JWT pop charger and replace the stock airbox before going to my dealer??
Sorry if my english is not very good.....
Thanks!!
Old Aug 1, 2010 | 02:18 PM
Beebo's Avatar
the clutch is not under warranty so they will not replace your clutch.
did you check the clutch fluid? i had the same problem a few months ago and it turned out the clutch fluid was leaking and they had to replace the master cylinder and the hose
EDIT: btw you do not need to remove your pop charger
Old Aug 1, 2010 | 02:22 PM
DrMax's Avatar
By cheked the fluid level in the reservoir or if the hose is leaking?
Old Aug 1, 2010 | 02:27 PM
Beebo's Avatar
if there is no fluid in the tank then check for leaks
Old Aug 1, 2010 | 02:31 PM
DrMax's Avatar
Tank is full
Old Aug 1, 2010 | 02:36 PM
Beebo's Avatar
hm not sure what the problem can be
Old Aug 1, 2010 | 04:23 PM
mjd240's Avatar
You busted your clutch. This is my prediction. Sorry. I have been thru this. Now I have a twin disk. Stock Infiniti clutches are organic junk for under $1000. You can get a stock clutch again, and break it again. Or go with an expensive $2200 twin disk and be done with the problem. At least, this is what I did.
Old Aug 1, 2010 | 05:12 PM
DrMax's Avatar
My clutch still working great but i know its not like it was before...i just want to know if my warranty cover my pedal problem. Its anormal that my clutch pedal is sticking and if this continue....i will burn it
Old Aug 1, 2010 | 05:16 PM
Hossmaxima's Avatar
I replaced those clutch line with a stainless steel clutch line and flushed out the clutch fluid, worked like a charm. Our regular hose line get really over heated and especially in very hot weather the rubber hose line gets over heated causing the clutch pedal to stick. try it out.
Old Aug 1, 2010 | 05:31 PM
nighthawk06's Avatar
My clutch pedal sometime made weird squeaky noises on the hot day. I changed the clutch fluid and it works better than before now. As far as I know, dealership don't cover clutch problem.
Old Aug 2, 2010 | 03:37 AM
Devo7's Avatar
Had the same problem and did the line change and mine feels great again its a simple change worth a try if you dont wanna deal with the dealer.
mbe32
Nov 13, 2015 11:09 PM
AL8782
Oct 3, 2015 10:26 AM
dcsbh1
Oct 1, 2015 03:15 PM
Hogbone
Sep 28, 2015 06:44 PM
jbmw002
Sep 10, 2015 12:54 AM
