Quickk question
Old Aug 3, 2010 | 04:33 PM
kday's Avatar
Quickk question
The LED lit keyring in my G35 is broken in a couple of places and a few pieces have already chipped away. I've done a few quick searched but can't quite find an answer. What would this part be called?
Old Aug 3, 2010 | 04:47 PM
spoolinupblue's Avatar
I looked it up for mine, 2003 G35 Coupe. It is called a "Key Lamp" and its $16.67
https://www.infinitipartsonline.com/...upe-parts.html
Steering Column / Shroud switches and levers / key lamp
Old Aug 3, 2010 | 04:54 PM
kday's Avatar
thanks spool! By any chance would the LED be easily replaceable ?
Old Aug 3, 2010 | 04:57 PM
once you get to that piece it should be.
a friend of mine here at work changed his to white....i am so jealous of him!
Old Aug 3, 2010 | 06:08 PM
surma884's Avatar
I've been wanting to do that. How do you get access to the LED? Do you have to remove the whole cover around it?
Old Aug 3, 2010 | 06:46 PM
VQ Johnny's Avatar
Its not the easiest due to the tight space but you have to remove the bottom finisher panel of the steering wheel and if you look up in there you should be able to see a long white plastic piece sticking out of the back just turn it 1/4 turn pull it out and replace the bulb it took me about 20 min but only cuz I have big hands and space in there is pretty limited.
Old Aug 3, 2010 | 07:41 PM
kday's Avatar
Awesome, I'll have the entire assembly apart when I am replacing it so it will probably be a little easier. Do you happen to know the bulb size?
Old Aug 3, 2010 | 08:17 PM
VQ Johnny's Avatar
T74, these are the leds I used you can get them in amber but I used the white and its much brighter
http://www.v-leds.com/Interior-LED/G...22390-1-2.html
Old Aug 3, 2010 | 08:26 PM
I just need to find time to do it.
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
migurus
Sep 5, 2015 09:39 PM
TheBay
Sep 3, 2015 03:27 PM
erich2780
Sep 3, 2015 03:23 PM
