Who has the highest mileage on their G35 & how are they holding up on the Long Haul
on
on
I am at a 178k miles. I just replaced the motor at 172k. Don't get your hopes up though mine was from using cheap paper fram filters I believe. I am now using Wix or K&N air filters which ever is cheaper. The car has needed some tie rod ends but, they may be because I was lowered with out a camber kit for a long time.
'04.5 here. but only 34k miles A few minor issues here and there, e.g. fuel tank sending unit, rattle in driver's seat and axle click (all fixed under warranty) but other than that running strong. When I sold my '92 300ZX in 2004, it had 79K miles on it and was running like a champ, though I did replace all the fuel injectors in '99.
My 06' just hit 40K. It's a 200K engine. I own a 00' 2K Se Maxima (with a VQ30) and it's at 250K. I've babied it since day one BUTT, it started acting up at around 200K.
I plan on doing a full engine build-up on my G at around 100K. Maybe a 300H.P. N/A engine. That one should last a while. This cars are fairly well made.
138k on 03 6mt coupe, already experienced every issue that every 03 coupe would expect except windows and power seat. (stereo, door lock, gear grind- improved with oil change, headlight hazed, loud throwout bearing)
still on original clutch and gets 21mpg
my past cars including two 240sx had over 200k miles and i am expecting the g does the same.
