how much oil do I use?
Old Jan 22, 2015 | 11:02 PM
herrschaft's Avatar
Originally Posted by g35S3
how much oil does it take to fill a g35 coupe
5 posts in this thread contain that answer. This response contains the correct numerical value.
Old Jan 23, 2015 | 12:30 AM
ScraggleRock's Avatar
It should always be 5qts. Even if you reuse the filter (which is OK, as most of them are good for 2 oil changes [although I never would]), you should still take it off and empty it of all the dirty old oil.
Old Jan 23, 2015 | 12:39 AM
gary c's Avatar
One more correct response to this thread...5 quarts of your favorite oil will fill your G to the full line! Since I answered this thread I've quit using AMSOIL and K&N filters due to going thru a quart between changes. Went back to Mobil1 10w/30 (Costco) and WIX oil filters, quit using oil...Gary
Old Nov 27, 2016 | 01:10 PM
partyman66's Avatar
You can't really get much of the oil out by doing this. Maybe a third of what's in there at most. I've cut open oil filters before after "draining" them. You'd be surprised how much is left.
Old Nov 27, 2016 | 01:38 PM
Sam G35S's Avatar
I'm 2nd gen but I'm using Wix filter and Castrol EDGE titanium oil! And I put 5 qt's also in my V36 GS.
Old Nov 28, 2016 | 02:45 AM
partyman66's Avatar
Are you using the Castrol Edge European Formula made in Belgium/Germany?
In case you aren't aware... Advance Auto has a sale that is on until the end of this month where you can get 5 quarts of Castrol Edge for $28. The Belgium-made 0W30 Euro formula is included in that as I bought some today at my local store. Probably worth picking up at least one batch of it if you've got a store nearby since this stuff is typically mega expensive.
Old Nov 28, 2016 | 05:02 AM
Blue Dream's Avatar
I drove ttrank's car solo
Just an FYI for all that use the bigger M45 filters like me. The 5+ qt. jugs, I believe it's 5.25 qts., fills the motor right to the top of the full line on the dipstick.........
Old Nov 28, 2016 | 06:15 AM
Sam G35S's Avatar
Yes I do,and I'll swing by and grab some oil then-I do appreciate your lookout.
Old Nov 28, 2016 | 06:17 AM
Sam G35S's Avatar
Blue Dream-is that applies only for 1st gen or for both? Thanks.
Old Nov 28, 2016 | 06:51 PM
Blue Dream's Avatar
I'm referring to first gen G's. Not sure on the second........
Old Nov 28, 2016 | 07:28 PM
Sam G35S's Avatar
Roger that,I'm thinking about installing a oil cooler on my along with oil pressure gauge and oil temp gauge.
Old Nov 29, 2016 | 05:45 AM
Blue Dream's Avatar
My 05 sedan has a factory oil cooler between the pan and the filter, I thought all first gen G's had one. You must be talking about an external cooler.......
Old Nov 29, 2016 | 06:20 AM
Sam G35S's Avatar
Yes Blue Dream I'm talking about an external oil cooler!
f22raptor
Mar 18, 2016 08:50 AM
prinny
Nov 22, 2015 11:07 PM
mbe32
Nov 13, 2015 11:09 PM
9tray turbo
Sep 29, 2015 10:22 PM
