Is my flywheel gone???
Old Aug 27, 2010 | 09:33 PM
tnmt_donkey's Avatar
Exclamation Is my flywheel gone???
Today, i was at a stop on a slop. I pressed half clutch to make my car stay and not roll back. After the traffic was clear, I released my clutch,.The car moved forward, but the clutch padel didn't come up fully. And I could smell something like burnt aluminum.
After I pulled the padel back, it is now working like normal.
What is probably the problem?? Flywheel, clutch set, or just the clutch cable??
And thank you first for you opinions...
Old Aug 27, 2010 | 11:34 PM
gary c's Avatar
Hmm, you say your clutch pedal was stuck and didn't come up all the way? I can tell you it has nothing to do with your flywheel, zip/nada. I know you're new here so if you'll try doing a SEARCH under subject "clutch pedal sticks" you'll find exactly what you're looking for....the answer. SEARCH is your friend, use it for any question!
Gary
Old Aug 27, 2010 | 11:43 PM
Saw the " clutch pedal sticks" thread right after I posted mine.
But what was that smell?? smells like something burnt.
so worry about my flywheel...
Old Aug 27, 2010 | 11:57 PM
gary c's Avatar
No, what you smelled wasn't the flywheel, likely the clutch surface....
Gary
Old Aug 28, 2010 | 12:47 AM
Thanks for the reply.
I know I am not a very good manual car driver... always worry about my clutch parts.
magnetism80
Feb 1, 2019 10:00 AM
AL8782
Oct 3, 2015 10:26 AM
Jpete
Sep 25, 2015 01:38 PM
bigmike
Sep 17, 2015 01:58 PM
ChickenTendrs
Sep 16, 2015 01:10 PM
