blown motor
Old Aug 31, 2010 | 01:48 AM
3rick35c's Avatar
Under Construction
Originally Posted by Jairen
This is not the first time I've heard of a random blown motor when cruising. Another local SD member also had the same thing happen. I think he also had an 04.
As for the used 07 motor, if it's a REVUP, chances are, there will be some differences in the wiring harness.
How hard were you on the motor? Another ideas on what happened? Timing chain, bearing failure, rod failure, etc?
not hard at all... I am trying to keep my 1 ticket in the system the only one in the system...so i really dont need to push the g hard for any reason...not to mention if you drive fast the girls in the other cars cant see the driver...hahaha but on a real note... the death blow sound came really low in the motor...nothing up top... I cant really tell what the fail is until i bring it to the shop... in which I am still trying to locate a decent motor...as we read...
Old Aug 31, 2010 | 01:52 AM
Jairen's Avatar
Engine mods?
Old Aug 31, 2010 | 04:50 AM
3rick35c's Avatar
Under Construction
fujita intake... greddy cat...
Old Aug 31, 2010 | 05:32 AM
JUM3's Avatar
subscribed, this is odd.. did you have anyone diagnose the failure?
Old Aug 31, 2010 | 05:44 AM
3rick35c's Avatar
Under Construction
not yet... I have experienced this before on B series and K series motor same symptoms... I know that these are completely diff motors but the symptoms of not being able to crank over can be a result of broken rod etc... but I will find out when the car is in the shop for a motor swap...I would love to strip that VQ just to see what really broke...
Old Aug 31, 2010 | 05:47 AM
3rick35c's Avatar
Under Construction
to be honest... I think the possible oil pooling problem caused all this... i would have to consider enough oil got into a cylinder to cause some thing similar to a hydro-locked motor...but i will never know until its stripped.
Old Aug 31, 2010 | 12:41 PM
XLR8_'s Avatar
Damm dude sorry to hear that my enigine is making a wierd noise like if somethin broke inside... Nut only does that on may 40-50mph ???
Old Aug 31, 2010 | 12:48 PM
jwrape's Avatar
Mine did the exact same thing... I thought it was the timing chain BUT when I pulled it I found that it was the pin in the Harmonic Balancer that connects the timing chain gear to crank shaft...
Old Aug 31, 2010 | 12:59 PM
Canadian's Avatar
Canada, eh?
My stock motor is sitting in San Diego now, if you're interested shoot me a PM. It's a 2006 NON REV UP so will work fine, as long as you use your same engine harness.
Old Aug 31, 2010 | 01:13 PM
3rick35c's Avatar
Under Construction
pm sent
Old Aug 31, 2010 | 03:42 PM
saywat?'s Avatar
i wanna slap the nissan design team that designed the unfitted looking nismo rear add ons
Old Sep 3, 2010 | 05:42 AM
andrewstclair's Avatar
whats this about a riverside meet i couldnt find anything on it?
Old Sep 3, 2010 | 10:56 AM
herrschaft's Avatar
https://g35driver.com/forums/socal-m...sept-19th.html
Old Sep 3, 2010 | 02:17 PM
_'s Avatar
_
how come you dont got the 06/07 tail lights/spoiler/projector headlights? Your car is a 03-05 not 07
Old Sep 3, 2010 | 02:25 PM
  #30
RacerX35's Avatar
If you get it right, you should have no problem with the motor swap. I blew the engine on my '03,,,,,,,,,,, actually on the Laguna Seca racetrack and towed the car back home. I bought a replacement with 17,000 miles on it for $1,600 in Fontana. Had a good friend with a shop and he swapped the motors for $1,200. Also, I had hydro locked the motor one time in Murrieta during a huge rain storm and a flooded street. Dealer ship checked it and figured I'd be getting a replacement. When they checked the engine, it was fine and strong as they told me. I did get a new tranny (under warranty) during that time at least. Good luck with your replacement.
Later,
Ray
