jack stand placement
you can put on frame, the 2 parallel bars running down most of the length in your car beside the transmission. or right next to the pinch welds. really really hard to explain, i'll try to post pictures if anything when i have the time
I use the frame welds as well towards the middle of the car. If you use the jack points intended for the portable jack (with jack stands), they will bend, especially the rear ones the front ones are a lot stronger. My question since were discussing jacking points is I have been jacking up the rear using the differential (pumpkin) is this safe or will it wear the diff bushings, i have been told it is ok..
Gary
If you read your manual "YOU'RE DOING IT WRONG!"
Again, if you read the manual there are jack points on the frame rail behind the front wheels and in front of the rear wheels. You can position the jack stands in those areas. I wouldn't jack up my coupe using the differential due to the extra stress you're putting on it and I wouldn't want to mess up my differential cooler/cover....
Gary
Gary
Lifting points are on page GI-42 of the service manual. The diff is specifically included as a jack point and there is also a point on the front subframe (behind the oil pan). The front point even has a cone shape to make it easier to find. This page recommends adapters that have a groove for the pinch welds, but these are hard to find. Some members have made their own. Some of my pinch welds are bent because I don't have adapters.
Don't forget to chock the wheels. Even if you are in gear and have the parking brake on, the car can start rolling if you lift the rear and the surface isn't completely level. I won't make that mistake again!
Other safety tips: Don't get under a car that isn't supported by stands, the jack does not count as a stand! Put your wheels under the frame for added insurance.
Gary
Old thread, but I'm resurrecting it. I understand that you want to put the jackstands under the manual recommended jack point for changing a tire, but physics doesnt allow 2 things to be in the same place at the same time. How do I jack my car up to put the jack stands under the jack point?
