jack stand placement
Old Sep 13, 2010 | 05:49 PM
rob40wilson03's Avatar
with the exception of the few of you who have made a custom adapter for your jack stands, where does everybody usually place their jackstands under the car?
i just want to know the safest spot (for me and my car)
thanks
Old Sep 13, 2010 | 05:54 PM
WhosRich's Avatar
Safest spot is the still the stock jack locations whether or not you have adapters.
Old Sep 13, 2010 | 06:10 PM
gary c's Avatar
thanks
Why would you make adapters for jackstands, to what purpose? I've placed my Sears 3 ton jackstands in the stock location (found in your owners manual) without incident several times being totally confident laying under her....
Gary
Old Sep 13, 2010 | 06:18 PM
dEnbOy.GFM's Avatar
^ probably wouldn't be here if you had an "incident" =P
Old Sep 13, 2010 | 10:16 PM
well the jackstands i have dont really fit there (the pinch welds)
here is what my jackstands look like
Old Sep 13, 2010 | 10:18 PM
msommers's Avatar
Is there something wrong with using the frame???
Old Sep 13, 2010 | 10:44 PM
not as far as i know, but im just not sure where on the frame is good
Old Sep 13, 2010 | 11:15 PM
walshtj's Avatar
Like Gary said look in the owners manual. It will show you exactly where you can. Its right behind the front tires on either side...
Old Sep 14, 2010 | 12:55 AM
RiversideS13's Avatar
you are welcome
http://www.harborfreight.com/2-piece...and-95952.html
Old Sep 14, 2010 | 01:47 AM
i honestly tried the manual, spent 10 minutes searching for anything relevant in the index, no luck but i found a suitable place on my car to put them and got lucky that it didnt screw anything up
Old Sep 14, 2010 | 12:04 PM
partyman66's Avatar
I use the lower control arms. Works fine unless you are doing suspension work. It kinda sucks having a unibody sometimes because jack points aren't always straightforward.
Old Sep 14, 2010 | 12:15 PM
FlyingMustache's Avatar
Originally Posted by RiversideS13
This! I also have the rubber pad for the jack too.
Old Feb 7, 2011 | 07:55 AM
w4kj4k's Avatar
bumping an old thread.
I know the people put he jack stands on the place that the manual shows, but is it safe to put it here too?
(driver side)
Old Feb 7, 2011 | 12:39 PM
sTeadFasT96's Avatar
My jack stand has a more flat top so I just put it on the pinch welds next to the little indented part of the pinch welds where you put the jack.
Old Feb 7, 2011 | 01:13 PM
w4kj4k's Avatar
Ahh i see.
But is the location where i put my jackstand, okay?
