How to Test MAF Sensor
Old Sep 21, 2010 | 04:28 PM
Ronjon17's Avatar
Hello all,
After replacing spark plugs my car is running incredibly rough. After lots of troubleshooting and testing different things I think I have narrowed it down and its actually not a spark plug problem and it is actually the MAF sensor.
OBD II Sensor displays the following codes:
P0102 (MAF Sensor)
P0113 (IAT High Temperature Circuit)
I have already reset the ECU
Is there a way to test the MAF sensor to see if it needs to be cleaned vs replaced? It's running very rough and you can smell unburnt fuel so I think it is more than just a cleaning. I am concerned that the harness actually might have been damaged while I was doing the spark plug change. I'm not too good with a multimeter although I do have one. Can someone describe to me in detail a step by step process on how to check the continuity of the wires? Also how to check MAF sensor to see if it is working or if maybe I am misdiagnosing?
Old Sep 21, 2010 | 05:26 PM
culi's Avatar
Get CRC MAS cleaner from automotive store and clean it. Also try to reset your throttle body position sensor. This is a separate procedure than the ECU reset.
https://g35driver.com/forums/faq-diy...cu-resets.html
Old Sep 21, 2010 | 06:11 PM
Ronjon17's Avatar
Yea I did both, I'm concerned tho about the harnessi think too much strain got on one of the wires while moving it around.
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
AT23
Sep 15, 2015 07:44 PM
n2fooz
Sep 4, 2015 07:46 PM
UT G35
Sep 3, 2015 03:58 PM
