Oil consumption issues
Sep 22, 2010 | 05:43 PM
For the second time in LESS than a week the dealer has found no oil in my engine. I have proof that it was topped off by another dealer and still they refuse to swap it under warranty for the fact they expect me to have all oil maintenance records over the life of the vehicle. I bought the car used. Is this a valid request of the dealer? They also said i have an aftermarket spacer but that it doesn't void my warranty. The tech said he thinks it was once turboed. Is this possible to prove? Where do i go from here
Reply 0
Sep 22, 2010 | 06:17 PM
Call up Infiniti of North America and explain your situation.
Reply 0
Sep 22, 2010 | 06:20 PM
Yea i did earlier but this was before they found no oil the second time. I called because the dealer wouldn't even look in to the fact i had no oil once already.
Reply 0
Sep 22, 2010 | 06:24 PM
Quote: For the second time in LESS than a week the dealer has found no oil in my engine. I have proof that it was topped off by another dealer and still they refuse to swap it under warranty for the fact they expect me to have all oil maintenance records over the life of the vehicle. I bought the car used. Is this a valid request of the dealer? They also said i have an aftermarket spacer but that it doesn't void my warranty. The tech said he thinks it was once turboed. Is this possible to prove? Where do i go from here
Yes this is a valid request by the dealer as Infiniti/Nissan Corp requires at maintenance record for car when they're about to replace a motor for oil consumption under warranty.
You should have done some research before buying a G35. I warn people all the time and people just brush if off. Thinking that they're safe buying an "Infiniti".
I bet you're also leaking oil to the spark plugs also. I'm guessing the previous owner knew the car was crap and couldn't wait to get rid of it.
Reply 0
Sep 22, 2010 | 08:22 PM
Lol this guy knows it all. The car came off lease from manheim auction and checked out in above average condition. The oil was changed like every other car that runs through manheim and you can't detect oil consumption without driving the car and having the issue occur. Also, no oil leaking in any of the cylinders. Your input is appreciated.
Reply 0
Sep 22, 2010 | 08:40 PM
How much miles on the car?
Reply 0
Sep 22, 2010 | 08:52 PM
52k. In service date is 04/04/2005. Still under powertrain coverage
Reply 0
Sep 22, 2010 | 11:43 PM
Print this TSB:
https://g35driver.com/forums/5304235-post1234.html
Read pg2 (flow-chart) Look at step 1 (oil change history....or not) end result is the same if you fail the consumption test.
And check this TSB when you do get replacement approved, make sure dealer commissions your replacement like this.
https://g35driver.com/forums/5212822-post1203.html
Dealers HATE when we know this stuff LOL!!
G/L
Reply 0
Sep 23, 2010 | 01:37 AM
^ ya, we do. However, if you've never ever been to the dealer for any kind of maintenance and you cannot produce records of your oil change history you cant expect to just stroll in and say hey my oil was low twice, gimme a new motor. Doesn't work that way..and you can't entirely blame the dealer, they have to report to and show documentation to corporate or else they can get audited. It also helps to do a service or 2 with the dealer so you have some kind of history with them, and will improve your odds for "good-willed" repairs down the road. People always think the dealer is trying to screw them when its usually the other way around (but i may be bias lol)
Reply 0
Sep 23, 2010 | 01:48 AM
Quote: Dealers HATE when we know this stuff LOL!!
Quote: ^ ya, we do... People always think the dealer is trying to screw them when its usually the other way around (but i may be bias lol)
Uhhh
Reply 0
Sep 23, 2010 | 02:21 AM
I wasnt so much as asking for a new motor today. All I wanted was for someone to look in to the fact that there is clearly a problem with my motor considering that within a week nearly 5 quarts of oil has been burned. Providing records of previous oil changes I understand, fair enough. However, i was told that because I did not have consistent records over the past 52,000 miles (life of the vehicle) that there was no one who would help me. I find it unbelieveable that completely disregarding the fact that i've only owned the car for 10k miles they expect me to be able to produce such records. The service writer clearly agreed that I had a consumption problem and wasnt willing to help me any way. He basically told me that i was on my own to contact infiniti and fight with them. unbelievable.
Reply 0
Sep 23, 2010 | 02:27 AM
I didn't have records of any maintenance and got mine replaced twice.
Reply 0
Sep 23, 2010 | 02:32 AM
^ yea sounds like a bunch or horse s**t to me. Im going back tomorrow with everything that ive read tonight, and the tsb flow chart. I dont get what their deal is.
Reply 0
Sep 23, 2010 | 03:05 AM
G/L
^^^^exactly. Skyline GT helped me through all of my oil consumption issues. He knows what hes talking about. Do exactly that. I had a lot of problems with my dealer too but they eventually gave me a short block after 3 OC tests. Never leave the car out of sight, ask questions first pretend to not know, then when they try to feed you some bs just tell them you have the TSB in your car and know the procedure. They can't stall for long.
If you do not have maintenance records they will strip your car down and check for sludge. If they find sludge your warranty will be completely taken away, and you have to pay for the tear down (atleast at my dealer). If there is only free flowing oil they will replace either the short or long block depending on what they "think" is the cause. Make sure the warranty has been transfered onto your name as well from the previous owner.
Reply 0
Sep 24, 2010 | 01:11 AM
Quote: ^ ya, we do. However, if you've never ever been to the dealer for any kind of maintenance and you cannot produce records of your oil change history you cant expect to just stroll in and say hey my oil was low twice, gimme a new motor..and you can't entirely blame the dealer, they have to report to and show documentation to corporate or else they can get audited. It also helps to do a service or 2 with the dealer so you have some kind of history with them, and will improve your odds for "good-willed" repairs down the road. People always think the dealer is trying to screw them when its usually the other way around (but i may be bias lol)
Sorry to hear that....well not really lol.
True, not the dealers fault such a high TSB claim cost, but it's not the Infiniti owner either. Corp created the TSB, released it and knows it's unusual high cost they'll pay you. If our consumption rate qualifies, SM talks to RM. RM talks to Corp...approved...done, oh and most likely no audit b/c of monthly warranty/non-warranty ratio became whacked out.
I've read so many stories (my past experience included) over the years and still do just on this TSB that's 180 out what you said. I had all service done at dealer since day one new too. This so-called Infiniti experience, still to date and why I still help owners, leaves a bad taste in my mouth from Infiniti Dealerships with their sneaky games to screw the owner while under warranty with this TSB
Reply 0
