anything wrong with using wheel spacers?
Old Sep 24, 2010 | 12:32 PM
Jaydm24's Avatar
I have spacers on my car as we speak and they work fine. 25mm in the rear and 20mm up front with OEM 19s.
Old Sep 24, 2010 | 12:39 PM
MJ-G35's Avatar
Ichiba V2...they come with built in lugs. Running 25mm all around, for bout a year no problems.
Old Sep 24, 2010 | 02:01 PM
w4kj4k's Avatar
For some reason eve IF its safe to use 5mm without extended lugs.. id still be iffy about it.
Old Sep 24, 2010 | 04:50 PM
[Rush]'s Avatar
G35 6MT
I've had Ichiba V2 (20mm front and 25mm rear) with my OEM 19" Rays on my G for four months and haven't had any problems.
IMO, with most things in the world -- it's all about how you do it. Do it right, or intelligently, or thoroughly -- and you'll be fine. Do it wrong, or poorly, or half-assed -- you're in trouble.
Old Sep 24, 2010 | 04:53 PM
w4kj4k's Avatar
We know that the spacers with the built in extended studs should be fine.
But the problem is when people buy spacers that you need to replace the oem studs and they dont.
Old Sep 24, 2010 | 04:59 PM
Chealy's Avatar
Don't buy off-brand spacers, stick with the well known brands like Kics or Ichiba. The extra money you spend on the quality brand versus the ebay brand is well worth it.
^^ If you go through recent threads in the wheels.tires section you'll see the consensus is it's not safe to do that. Some have suggested that "maybe' a 3 mm spacer would be OK (ttrank) but to be safe you need extended lugs with any spacers. I actually started a question thread on this topic a couple of months ago because I have no experience with the and was curious. https://g35driver.com/forums/wheels-...gs-needed.html
When you are saying "extended lugs" do you mean extended studs??? I'm confused... Lugs and studs are being used in the same context, but they are two completely different things.
Old Sep 24, 2010 | 05:13 PM
XiN's Avatar
XiN
Supersonic... Hypertonic
Itasha Coupe
^^ Yes he means studs.
Old Sep 24, 2010 | 07:14 PM
Blue Dream's Avatar
I drove ttrank's car solo
Sorry about that, I did mean studs. Thanks for having my back Son!!
Old Sep 24, 2010 | 07:21 PM
XiN's Avatar
XiN
Itasha Coupe
^^ I guess I'm good for something.
Now tell your cat to stop punching me.
Old Sep 24, 2010 | 08:30 PM
Blue Dream's Avatar
haha you've been pvssy whipped!!
See you tomorrow.
Old Sep 24, 2010 | 09:17 PM
TDTh3Boss's Avatar
alright i mean so you guy are saying if i get extended studs then i should have no problems with spacers?
Old Sep 24, 2010 | 09:33 PM
herrschaft's Avatar
^Yep. You could just get the ones with the studs already built in like the Ichiba V2's.
Old Sep 24, 2010 | 11:56 PM
nikkaitsme's Avatar
No problems here
jsimonk
Dec 22, 2023 03:49 PM
paolojericho11
Sep 11, 2015 07:08 AM
tphan
Aug 31, 2015 10:45 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
