5mm spacer...extended lugs needed?
Old Jul 20, 2010 | 10:16 AM
Blue Dream's Avatar
I drove ttrank's car solo
Sorry for the noob question but I've read multiple opinions on this topic. If I put 5mm spacers on my front wheels is it necessary to use the extended lugs? After all 5 mm is only .196850393701 inches. I have 5Zigen Gravis 1s if that needs to be added into the equation.
TIA for your thoughts.
Old Jul 20, 2010 | 10:29 AM
CandlestickPark's Avatar
ill Sedan
Tim I needed extended lugs when I added a 5mm spacer up front. Not sure if my BBK factored into it at all as well, but I couldn't get the 7 or 8 turns of the lug nut that I think is recommended.
Old Jul 20, 2010 | 10:35 AM
Calvin's Avatar
Overglorified Altima
^^^BBK wouldn't affect that. Spacers larger than 3mm should use extended lugs on our cars.
Old Jul 20, 2010 | 01:58 PM
Blue Dream's Avatar
Thanks guys that's what I suspected. Have to get the correct tires on the rims this weekend and I'll be able to figure out what I need. Might be up to 15mm which would mean I could get the V2s with the built in studs.
Old Jul 20, 2010 | 02:30 PM
G35Papa's Avatar
If your rims are flat in the back where it bolts up to the hub, you may have to cut the OEM studs so the rim will sit flush....something to look into/consider if you wind up getting the 15mm spacers with the built in studs. All OEM wheels have the "pockets" to clear the studs that stick out but some aftermarket wheels don't.
Old Jul 20, 2010 | 02:40 PM
G2FLIP4's Avatar
everything
Thats what I had to do. Cut off like .25" of my stock studs so they wouldnt go past the spacer and prevent the rim from seating on the hub properly. Im running 10mm in the rear. The thinner the spacer the more likely hood the stock studs will stick out too far.
Old Jul 20, 2010 | 02:41 PM
Blue Dream's Avatar
Thanks Papa, my 5zigen do have the pockets which will allow me to go built in. I made sure I looked at that when I bought them. I did have to buy hub centric rings though for the rims. They didn't come with any.
Old Jul 20, 2010 | 08:09 PM
G2FLIP4's Avatar
everything
My wheels have pockets also but I still have to grind down the OEM studs.
Old Jul 22, 2010 | 02:17 PM
by15vc's Avatar
^^With the 10mm spacer you definitely need to if you're running the v2. Blue Dream is referring to 15mm and he should be fine with those.
wuppiedog
Engine - Exhaust
Sep 6, 2015 12:07 PM
netcbc
Wheels & Tires CDN
Aug 25, 2015 09:42 AM
BlackGee35
Jul 31, 2015 11:04 AM
