Engine oil Brand
Old Oct 4, 2010 | 09:34 PM
  #61
whoisthis's Avatar
Originally Posted by Louisiana G35
I was thinking the same thing. The G35 and 350Zs are suppose to run on 5w30 oil. The 0w30 your using is to thin..
actually castrol0w30 is thicker than 5w at operating temp. I will try 5w30 next oil change but I like 0w30 castrol other than the ticking noise lol
Old Oct 4, 2010 | 11:57 PM
  #62
partyman66's Avatar
Yep... I've read the same thing about that oil being thicker than equivalently rated viscosity oils.
The 0W cold rating isn't going to harm your car... it's only at 0 Weight for a very short time when the oil is dead cold and the difference is negligible between that and a 5 weight. Once your car starts to reach about 130 or more degrees F, the viscosity is rising closer to a 30 weight, and is a full 30 weight at operating temperatures. You shouldn't be driving your car hard when it's dead cold anyways.... but, for most people, the oil is going to be at around 130+ degrees after the car has been running for only 1 minute or less. Keep in mind that our cars have coolant temperature gauges, not oil temperature gauges(unless you install an oil temp gauge), so you can't really go by that gauge to tell how warm the oil is... and even if you could, there's no numbers on it.
They measure those 2 oil weights at 40 and 100 degrees Celsius(104 and 212 degrees Fahrenheit), and that's how you get the multi-grade rating.
Old Oct 5, 2010 | 11:00 AM
  #63
BW350GTskyline's Avatar
Hey guys i been putting in nothing but mobile 1 5w30 fully synthetic in the winter and switch between 10w 30 fully synthetic for the summer.. My engine runs clean no problems with the ticking... but at around 2200 miles in on the oil change if i am holding 2500 RPMs steady the engine at around then usually makes a different noise when i am cruising the highway.. should i switch to something different any preferences guys i am up for?
Old Oct 5, 2010 | 04:21 PM
  #64
SER-G35's Avatar
Has anyone use Eneos?????I want to use this oil for my next oil change but I haven't seen any feedback on it...
Old Oct 5, 2010 | 05:25 PM
  #65
whoisthis's Avatar
Eneos is dayuum expensive for an oil change
Old Oct 5, 2010 | 06:26 PM
  #66
SER-G35's Avatar
^ but is it good oil????
Old Oct 5, 2010 | 07:04 PM
  #67
whoisthis's Avatar
idk. I couldn't find a UOA on this oil
Old Oct 5, 2010 | 07:59 PM
  #68
SER-G35's Avatar
^ yeah I couldnt find much info on this oil...all I know is that its made in japan..
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
ghost_g35
Aug 7, 2015 10:31 AM
keithk831
Steering & Suspension
Aug 2, 2015 09:50 PM
ClwMike
Jul 23, 2015 12:55 PM
