Tow truck screwed up my g35... I need help!!
Old 10-10-2010 | 10:15 PM
HangUp n' Drive's Avatar
Even if the radiator was broken beforehand, how can they explain the pop and steam from an engine that is not running? I think you may have a burned up engine, and the engine melting down grossly overheated the cooling system. A slam-dunk in your favor if this proves to be true.
  #49
Old 10-10-2010 | 10:22 PM
chris_g8's Avatar
im just assuming that he left it in gear because no one has an idea of how the radiator burst...its mind boggling.... and also i baby the g35... it only has 40,000 miles
  #51
Old 10-10-2010 | 10:38 PM
chris_g8's Avatar
but i also want to protect my *** because he can easily say that there was prior damage to the engine and tranny because if i take the blame for the rad, he can easily say there was more stuff wrong with the car.... i came on this forum to find out if someone on this forum can have an explanation on how the rad burst... so far i liked all the responses but no one has hit the nail on the head yet
  #52
Old 10-10-2010 | 11:08 PM
My theory is; car was towed in low gear, overreving the engine. Something breaks, if the engine had been running it would stop and that would be the end of it. However the engine in this case is being driven by external force. Continuing to spin with broken pieces and breaking more, trying to seize but it cant, developing tremendous amounts of heat violently boiling the coolant. Either that, or the alien spacecraft's heat ray. Best I can do man.
  #53
Old 10-10-2010 | 11:15 PM
bigjee's Avatar
Take the G to the dealership.
Get it inspected.
If its a problem with the radiator then get it repaired.
If there are issues with the engine/transmission then get CAA to repair it through the dealership.
If they don't accept the cost of repair by the infiniti dealership then call an attorney.
The way i see it you're partially at fault. And if the CAA flat bed driver hadn't told you that the car was towed wrong then you wouldn't have known any better.
Basically if its a radiator problem then take the hit and make this a learning experience.
If its the engine / tranny then make CAA pay for it.
  #54
Old 10-10-2010 | 11:19 PM
bigjee's Avatar
To all those who think the engine was running when the radiator burst at 50 miles an hour:
Wouldn't the car be making a loud sound if the engine is revving close to the red line?
How could the driver hear the cap pop over the sound of an engine that is close to red lining?
Either the drivers lying or the engine wasn't running.
  #55
Old 10-10-2010 | 11:30 PM
Eric@TCGMiami's Avatar
The last time I give my 2 cents in this thread..
Before you do anything else, before you even think about clicking Post Reply..
CALL A F U C K I NG ATTORNEY
  #56
Old 10-10-2010 | 11:36 PM
herrschaft's Avatar
^What are you trying you say again?
I doubt the noise would be very loud since there's no combustion.
  #57
Old 10-10-2010 | 11:45 PM
Imagine your hand stuck in 1st gear jerking your **** @ 6600RPM ....
Now imagine that same scene with NO LUBE!
Remember fuel is NOT only a power source it is also a cooling source. the more fuel you add the less the temperatures will be. (hence why when you run lean the car gets hotter and tends to ping/knock.)
He's right!
But you'd still have friction; and friction causes heat and metal to metal contact causes noise. Not intense, but noise none the less.
By the engine turning it will still cause the oil pump to rotate and the subsequently the water pump as well. UNFORTUNATELY if will NOT mean that the electronics are on therefore the fan's will NOT kick on.
This guy has MASSIVE engine and/or transmission failures due to the extent of that damage.
  #58
Old 10-11-2010 | 12:08 AM
chris_g8's Avatar
**** your hilarious AltimanGxe.... im pissin my pants laughing
  #59
Old 10-11-2010 | 12:16 AM
I can only hope my comical posts have enlighten you to actually take heed and call an attorney tomorrow morning.
Because the more the times passes by the less chances you have at winning the legal battle.
Ps, you can have the attorney go after their labor costs from them (them being the towing corporation)
  #60
Old 10-11-2010 | 06:22 AM
bigjee's Avatar
If the pistons are moving fast enough for the radiator cap to pop I'm pretty sure they're moving fast enough to ignite any fuel in the cylinder causing a combustion.
Quick Reply: Tow truck screwed up my g35... I need help!!
