water rushing sound after install of Motordyne spacer
Old Oct 12, 2010 | 09:05 AM
bina12834's Avatar
so i recently installed the motordyne ISO 5/16" spacer with the valve. the valve is currently closed because its above 55 degrees here in DC. Ever since i installed the spacer ive been hearing a liquid rushing type sound everytime i accelerate from a stop. doesnt matter how hard or soft i push it from a stop, i always here it. it sounds like its coming from the driver side around where the brake fluid reservoir is. Is this normal after installing the motordyne iso spacer?
Old Oct 12, 2010 | 10:14 AM
LordFappington's Avatar
You may have a leak in the valve and you lost a lot of coolant. I would check your coolant level.
Old Oct 12, 2010 | 10:15 AM
bina12834's Avatar
ive had the spacer on for a good few months now and i havent ever over heated or anything. and ive even checked around the valve to see if there was any signs of leaking and i havent seen anything. ill check the level though.
Old Oct 12, 2010 | 01:14 PM
walshtj's Avatar
It may just be the spacer. Mine does this sometimes but it kinda sounds like a turbo spooling up, kinda...
Old Oct 12, 2010 | 01:17 PM
bina12834's Avatar
its definitely an unmistakable liquid gushing sound.
Old Oct 12, 2010 | 01:35 PM
walshtj's Avatar
Not sure then... I have checked all my fluids and they are fine so not sure. BTW bina like your post count, 666 and I was just up in NOVA for the Skins game Sunday!
Old Oct 12, 2010 | 01:37 PM
That1GuyG35's Avatar
this is a perfect excuse to put it on a dyno. pop the hood and investigate!
Old Oct 12, 2010 | 01:38 PM
bina12834's Avatar
you saw a good game then. im not a skins fan myself, but i enjoyed watching it on tv.
Old Oct 12, 2010 | 09:46 PM
Footballmania32's Avatar
Lol sounds like wishful thinking
Old Oct 12, 2010 | 11:02 PM
SiouxFallsG35's Avatar
Air in the cooling system is my guess. Need to burp your system (pretty common when working on cooling system). Usually involves opening the radiator cap (CAUTION) and then squeezing the large upper coolant hose. The idea being that any air in the system will work it's way out by doing the burp. I don't know how easy it is to get your hands on the G35 upper hose though. Seemed a little buried last time I looked.
Old Oct 12, 2010 | 11:34 PM
rain1119's Avatar
Recently, I've also noticed a liquid gushing sound whenever I am accelerating from a stop. I do not have any mods under the hood though. I'll post back if I have findings on the cause. Please do the same.
Old Oct 13, 2010 | 05:41 AM
LMG_35C's Avatar
When you burp the coolant system make sure the heater is on fully to force coolant through the whole system. If you actually hear this from inside the cabin then it must be coming from the heater core. Replacing spacer should have had nothing to do with this unless you disconnected the TB heater line without clamping it like most instructions warn.
Old Oct 13, 2010 | 07:04 AM
TIRE_SMOKE96's Avatar
This may sound silly but I hope you didn't install the valve upside down.
Old Oct 13, 2010 | 08:47 AM
bina12834's Avatar
do you know where the TB heater line is located? I followed the directions that Motordyne sent to a T.
Old Oct 13, 2010 | 08:48 AM
bina12834's Avatar
pretty much impossible to do....
