Clutch or Transmission?
So I was driving one night and accidently shift from 5th to 3rd by accident when I was trying to switch to 6th.. and realized I killed my cluch during the process... now I smell a horrible burnt clutch smell at times... I also realized there is a lag when on my RPM around 2500RPM (I would shift to higher gear and when it reaches to about 2500 -2700 RPM it lags a bit -idle-). I am not sure what is wrong. Is this a transmission or clutch issue? Or is it something else that could have caused the RPM do to that...
Help please
Help please
I was wondering the same thing.. must have been a brain fart, thinking 6th, but somehow just went to 3rd.
if you clutch is fading, you will notice as soon as you floor it going up hill in a higher gear, say 5th doing 50 mph. You will notice that the RPM's will increase but the speed won't. This is because the clutch is slipping.
I do notice the lag when i was in 4th/5th/6th especially tonight... lag to much i felt the RPM drop a bit while pushing it... how much longer until I have to get a new clutch and what is the cost of new clutch/install?
Thanks!
Thanks!
So i took it to a shop and they say its probably transmission also. The thing is I want a 2nd opinion at another shop.
Every gear seems to engage slowly. For example, if im at first, my RPM will go up but my speed will not. Very hard for me to accelerate when shifting into gear.
I do not want to spend an arm or a leg for a new transmission if that is the case and also the clutch will probably expensive to begin with so I need to diagnosis this correclt.y
Thanks for any feedback.
jbmw002
Sep 10, 2015 12:54 AM
