Scratched Door Pull Trim
Old Oct 15, 2010 | 07:34 PM
dukehotty's Avatar
Smile Scratched Door Pull Trim
Hey guys,
I had lots of scratches on the driver side door trim so I decided to sand the scratches and ended up sanding the whole thing. It actually matches the alum. trim in my 06 much better.
To take off the door pulls, insert a flat head screwdriver into the little slot towards the bottom of the door pull. It should just pop off.
I used 350 grit to take off the paint, then I used 1000 grit to smooth it out. It's really important to sand in the same direction or you will end up with crossing lines in the alum.
After that, I used some "Mothers" polish to get rid of the fingerprints. I am sure you can continue polishing it and make it really shiny.. but I wanted it to match my console.
Old Oct 15, 2010 | 10:12 PM
NjMatteSedan's Avatar
Old Oct 16, 2010 | 03:56 AM
dukehotty's Avatar
Please keep the cookie. Your mom baked me some last night.
Old Oct 16, 2010 | 04:08 AM
jibberjabbers's Avatar
Old Oct 16, 2010 | 06:11 AM
Blue Dream's Avatar
I drove ttrank's car solo
Old Oct 16, 2010 | 01:07 PM
cuz she felt bad you're so ugly
Old Oct 18, 2010 | 04:27 PM
DT35G's Avatar
Looks like it came out good bro....
Old Oct 18, 2010 | 07:18 PM
gary c's Avatar
It's possible you could have accomplished the same results by using a very fine polishing compound or cleaner wax if it wasn't too bad. I took the easy way out, ordered some c/f overlays for my pulls so I will never have to screw with it again....ever!
Gary
Old Oct 18, 2010 | 07:50 PM
rotor7vent2's Avatar
is the door pull trim the same shape in all the models? because ive noticed the 06 models have real aluminum as opposed to my 04 which is plastic painted silver
aktif8
2nd Gen (V36) Sedan
30
Aug 5, 2017 11:47 PM
tiguy99
Mar 1, 2016 11:42 AM
will091195
Jul 27, 2015 09:19 PM
